[postgis-users] ST_Quantile
Bborie Park bkpark at ucdavis.edu
Fri Jan 27 11:27:34 PST 2012
Joan,
I confirm that there is a segfault.  Can you add a ticket for this?
I'll take a look ASAP.
-bborie
On 01/27/2012 11:19 AM, Joan wrote:
> Hi Steve,
> I have gotten the same problem (db server stopped running).
> Joan
> On 27 January 2012 20:05, Stephen Woodbridge<woodbri at swoodbridge.com>wrote:
>> Joan,
>> I've never used these function, but try doing:
>> select st_quantile('kbd_ext', 'rast', 0.75);
>> Since you probably do not want this called once for every row in the table.
>> -Steve
>> On 1/27/2012 2:03 PM, Joan wrote:
>>> Hi Bborie,
>>> This is my query and it crashes the db server.
>>> select st_quantile('kbd_ext', 'rast', 0.75) from kbd_ext limit 10;
>>> Joan
>>> On 27 January 2012 19:14, Bborie Park<bkpark at ucdavis.edu
>>> <mailto:bkpark at ucdavis.edu>>  wrote:
>>>     Hey Joan,
>>>     Assuming your whole coverage is in a table, you should use the
>>>     table/column version of ST_Quantile (which by the looks of it is
>>>     undocumented for some reason).
>>>     The function definition of ST_Quantile(rastertable, rastercolumn) is...
>>>     st_quantile(rastertable text, rastercolumn text, nband int DEFAULT
>>>     1, exclude_nodata_value boolean DEFAULT TRUE, quantiles double
>>>     precision[] DEFAULT NULL)
>>>     At the moment an aggregate version of ST_Quantile (and the other
>>>     basic stats functions) does not exist.  It is expected that one will
>>>     be written for PostGIS 2.1 assuming dev-time is available.
>>>     -bborie
>>>     On 01/27/2012 09:06 AM, Joan wrote:
>>>         Hi,
>>>         I would like to find the quantile values of a whole raster
>>>         coverage, but
>>>         ST_Quantile returns quantile values of each tile. Which would be
>>>         the best
>>>         method to approximate the quantile value of the whole coverage?
>>>         Regards,
>>>         Joan
>>>         ______________________________ _________________
>>>         postgis-users mailing list
>>>         postgis-users at postgis. refractions.net
>>>         <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>         http://postgis.refractions. net/mailman/listinfo/postgis- users
>>>         <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>     Bborie Park
>>>     Programmer
>>>     Center for Vectorborne Diseases
>>>     UC Davis
>>>     530-752-8380
>>>     bkpark at ucdavis.edu<mailto:bkpark at ucdavis.edu>
>>> ______________________________**_________________
Bborie Park
Programmer
UC Davis
530-752-8380
