[postgis-users] PostGIS 1.5.8
Stephen V. Mather svm at clevelandmetroparks.com
Fri Nov 16 11:46:45 PST 2012
Just a hunch, but make sure you are running that query on the database that
has postgis enabled.  If you run it on another database, you would get that
error.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Martin
Feuchtwanger
Sent: Friday, November 16, 2012 2:24 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 1.5.8
When I went through the OpenGeo Intro to PostGIS a couple of weeks ago,
there was a suggestion (at
http://workshops.opengeo.org/postgis-intro/creating_db.html) to issue the
query, from pgAdmin:
SELECT postgis_full_version();
The results in the example included PosGIS 1.5.1 and GEOS 3.2.3 which, given
the time lapse (2008-2012), seem quite compatible with Paul's current
announcement.
However, at the time, i thought i got this version number: PostGIS 2.0.1
To check, i've just reissued the query, but i got
ERROR:  function postgis_full_version() does not exist
LINE 1: SELECT postgis_full_version();
Two beginner's questions:
1.	Where might i have got "2.0.1" for PostGIS from?
2.	Why would i get the above error message?
Thanks,
Martin Feuchtwanger
On 15/11/2012 11:22 AM, Paul Ramsey wrote:
To go with the GEO 3.3.6 release, ... we are pleased to bring you PostGIS
1.5.8:
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121116/d46056ea/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121116/d46056ea/attachment.png>
