[postgis-users] ST_RotateX with pointOrigin!
Stephen Mather stephen at smathermather.com
Sat Dec 14 22:29:56 PST 2013
I have ticketed.  It's a little messy of a ticket (actually two), so
apologies for that.
http://trac.osgeo.org/postgis/ticket/2570
http://trac.osgeo.org/postgis/ticket/2571
I have not yet written any unit tests.  Where would I begin...
On Sun, Dec 15, 2013 at 1:02 AM, Bborie Park <dustymugs at gmail.com> wrote:
> Sweet. Can you create a ticket and attach the patch?
> Some unit tests would be nice so that expected behavior is maintained...
> and bugs are caught.
> Thanks!
> -bborie
> On Sat, Dec 14, 2013 at 7:57 PM, Stephen Mather <stephen at smathermather.com
> > wrote:
>> Ahem-- bugs fixed:
>> -- Function: st_rotatex(geometry, double precision, geometry)
>> CREATE OR REPLACE FUNCTION ST_RotateX(geomA geometry, rotRadians
>> double precision, pointOrigin geometry)
>>   RETURNS geometry AS
>> $BODY$
>> ----- Transform geometry to nullsville (0,0,0) so rotRadians will take
>> place around the pointOrigin
>> WITH transformed AS (
>>     SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
>> ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
>> ----- Rotate in place
>> rotated AS (
>>     SELECT ST_RotateX(the_geom, rotRadians) AS the_geom FROM transformed
>> ----- Translate back home
>> rotTrans AS (
>>     SELECT ST_Translate(the_geom, ST_X(pointOrigin),
>> ST_Y(pointOrigin), ST_Z(pointOrigin)) AS the_geom
>>     FROM rotated
>> ----- profit
>> SELECT the_geom from rotTrans
>> $BODY$
>>   LANGUAGE sql VOLATILE
>>   COST 100;
>> On Sat, Dec 14, 2013 at 8:37 PM, Stephen Mather
>> <stephen at smathermather.com> wrote:
>> > Hi All,
>> > I think I avoided doing linear algebra, which is good since I never
>> > studied it... .
>> > This is my cludgy patch for making a version of
>> > geometry ST_RotateX(geometry geomA, float rotRadians, geometry
>> pointOrigin)
>> > It's not pretty enough to be a real patch ('cause my brain couldn't do
>> > that whole linear algebra thing, and hence why it's here and not the
>> > developers list), but thought I'd share it anyway and get impressions,
>> > and have some brighter minds make sure I don't have some major logic
>> > failure here:
>> > DROP FUNCTION st_rotatex(geometry,double precision,geometry);
>> >   RETURNS geometry AS
>> > $BODY$
>> > rotated AS (
>> >     SELECT ST_RotateX(the_geom, rotRadians) FROM transformed
>> > rotTrans AS (
>> >     SELECT ST_Translate(geomA, ST_X(pointOrigin), ST_Y(pointOrigin),
>> > ----- profit
>> > $BODY$
>> >   COST 100;
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131215/6ac20147/attachment.html>
