[postgis-users] ST_RotateX with pointOrigin!
Bborie Park dustymugs at gmail.com
Sun Dec 15 10:29:47 PST 2013
Start in the regress directory found in the root of the postgis source.
You'll see that there are always two files for any particular test
(MYTEST.sql and MYTEST_expected). To include MYTEST as part of "make
check", you add MYTEST to regress/Makefile.in
-bborie
On Sat, Dec 14, 2013 at 10:29 PM, Stephen Mather
<stephen at smathermather.com>wrote:
> I have ticketed.  It's a little messy of a ticket (actually two), so
> apologies for that.
> http://trac.osgeo.org/postgis/ticket/2570
> http://trac.osgeo.org/postgis/ticket/2571
> I have not yet written any unit tests.  Where would I begin...
> On Sun, Dec 15, 2013 at 1:02 AM, Bborie Park <dustymugs at gmail.com> wrote:
>> Sweet. Can you create a ticket and attach the patch?
>> Some unit tests would be nice so that expected behavior is maintained...
>> and bugs are caught.
>> Thanks!
>> -bborie
>> On Sat, Dec 14, 2013 at 7:57 PM, Stephen Mather <
>> stephen at smathermather.com> wrote:
>>> Ahem-- bugs fixed:
>>> -- Function: st_rotatex(geometry, double precision, geometry)
>>> CREATE OR REPLACE FUNCTION ST_RotateX(geomA geometry, rotRadians
>>> double precision, pointOrigin geometry)
>>>   RETURNS geometry AS
>>> $BODY$
>>> ----- Transform geometry to nullsville (0,0,0) so rotRadians will take
>>> place around the pointOrigin
>>> WITH transformed AS (
>>>     SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
>>> ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
>>> ----- Rotate in place
>>> rotated AS (
>>>     SELECT ST_RotateX(the_geom, rotRadians) AS the_geom FROM transformed
>>> ----- Translate back home
>>> rotTrans AS (
>>>     SELECT ST_Translate(the_geom, ST_X(pointOrigin),
>>> ST_Y(pointOrigin), ST_Z(pointOrigin)) AS the_geom
>>>     FROM rotated
>>> ----- profit
>>> SELECT the_geom from rotTrans
>>> $BODY$
>>>   LANGUAGE sql VOLATILE
>>>   COST 100;
>>> On Sat, Dec 14, 2013 at 8:37 PM, Stephen Mather
>>> <stephen at smathermather.com> wrote:
>>> > Hi All,
>>> > I think I avoided doing linear algebra, which is good since I never
>>> > studied it... .
>>> > This is my cludgy patch for making a version of
>>> > geometry ST_RotateX(geometry geomA, float rotRadians, geometry
>>> pointOrigin)
>>> > It's not pretty enough to be a real patch ('cause my brain couldn't do
>>> > that whole linear algebra thing, and hence why it's here and not the
>>> > developers list), but thought I'd share it anyway and get impressions,
>>> > and have some brighter minds make sure I don't have some major logic
>>> > failure here:
>>> > DROP FUNCTION st_rotatex(geometry,double precision,geometry);
>>> >   RETURNS geometry AS
>>> > $BODY$
>>> > rotated AS (
>>> >     SELECT ST_RotateX(the_geom, rotRadians) FROM transformed
>>> > rotTrans AS (
>>> >     SELECT ST_Translate(geomA, ST_X(pointOrigin), ST_Y(pointOrigin),
>>> > ----- profit
>>> > $BODY$
>>> >   COST 100;
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131215/c6e243c0/attachment.html>
