[postgis-users] [postgis-devel] SFCGAL : trouble installing
Oliver Courtin olivier.courtin at oslandia.com
Mon Oct 14 13:36:42 PDT 2013
Le 14 oct. 2013 à 17:12, Rémi Cura a écrit :
Rémi,
> [SOLVED]
Goodie,
> I had to put permissive rights on the libSFCGAL.* file in "/usr/local/lib"
> (chmod 777)
755 should be enough…
> Thanks again Olivier for help !
You're welcome, any feedback at this stage is really appreciated...
> PS : may I suggest to add those lines at the end of the "installation" page in the github of SFCGAL.
> Right now (and until 2.2.0) sfcgal doesn't use EXTENSION
> so we need to create the spatial database with the old school method:
> cd /usr/share/postgresql/9.3/contrib/postgis-2.1
> psql -d your_database -f postgis.sql
> psql your_database -f  spatial_ref_sys.sql
> psql your_database -f  sfcgal.sql
Well even if SFCGAL is for now use in conjunction with PostGIS,
we could imagine to use it without PostGIS…
(as others softwares than PostGIS use GEOS too)
So this documentation installation step is more relevant in PostGIS doc…
And your right i was supposed to write SFCGAL Install Part in 8.10,
and still not done it...
http://postgis.net/docs/manual-dev/reference.html#reference_sfcgal
I will so do it soon !
Right now the more recent documentation related to installation/usage
is the FOSS4G Workshop about PostGIS 3D:
https://github.com/Oslandia/Workshops/tree/master/FOSS4G_2013_PostGIS_3D
HTH,
O.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131014/fc5e4eaf/attachment.html>
