[postgis-users] [postgis-devel] SFCGAL : trouble installing
Rémi Cura remi.cura at gmail.com
Tue Oct 15 00:58:35 PDT 2013
Np =)
Thanks for the Workshop, from now I'll refer to it before asking questions !
I'll post here if I encounter problems (or sucesses) with SFCGAL.
Cheers,
Rémi-C
2013/10/14 Oliver Courtin <olivier.courtin at oslandia.com>
> Le 14 oct. 2013 à 17:12, Rémi Cura a écrit :
> Rémi,
> [SOLVED]
> Goodie,
> I had to put permissive rights on the libSFCGAL.* file in "/usr/local/lib"
> (chmod 777)
> 755 should be enough…
> Thanks again Olivier for help !
> You're welcome, any feedback at this stage is really appreciated...
> PS : may I suggest to add those lines at the end of the "installation"
> page in the github of SFCGAL.
> *Right now (and until 2.2.0) sfcgal doesn't use EXTENSION*
> *so we need to create the spatial database with the old school method:*
> *cd /usr/share/postgresql/9.3/contrib/postgis-2.1*
> *psql -d your_database -f postgis.sql
> *psql your_database -f  spatial_ref_sys.sql*
> *psql your_database -f  sfcgal.sql*
> Well even if SFCGAL is for now use in conjunction with PostGIS,
> we could imagine to use it without PostGIS…
> (as others softwares than PostGIS use GEOS too)
> So this documentation installation step is more relevant in PostGIS doc…
> And your right i was supposed to write SFCGAL Install Part in 8.10,
> and still not done it...
> http://postgis.net/docs/manual-dev/reference.html#reference_sfcgal
> I will so do it soon !
> Right now the more recent documentation related to installation/usage
> is the FOSS4G Workshop about PostGIS 3D:
> https://github.com/Oslandia/Workshops/tree/master/FOSS4G_2013_PostGIS_3D
> HTH,
> O.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131015/57ffe682/attachment.html>
