[postgis-users] PostGIS user interface
Spencer Gardner spgardner at HNTB.com
Wed Feb 26 12:12:31 PST 2014
Just to add to some of the previous responses: GIS can refer to an entire ecosystem of storing, maintaining, and visualizing geographic data but is also sometimes used to refer to a single part of that ecosystem.
PostGIS would be an excellent option for storing the information that you describe, including the spatial information.
As for visualizing and manipulating data, there are a number of options that depend primarily on your particular needs. QGIS has been mentioned and is among the more popular options. You can also connect to PostGIS with ESRI's ArcMap (although I wouldn't recommend that because of its limited functionality). You could also build a web interface that connects to PostGIS on the backend and displays information and receives inputs according to your specific use case.
QGIS is free and offers some customizability but may require training in its use depending on what kind of experience you have with GIS terminology and processes. ArcMap is not free and would likewise require training depending on experience. A web interface can be built to your specifications (such that little inherent GIS knowledge is required) but would probably require the services of a consultant. Since you're in Minneapolis, you might check out Flat Rock Geographics<http://www.flatrockgeo.com/> as an example based in your backyard. You could also look at the list of companies that provide commercial support for PostGIS<http://postgis.net/support> (see heading Commerical Support) who likely have extensive experience assisting organizations just like yours.
Good luck!
Spencer Gardner, AICP
Transportation Planner
HNTB Infrastructure
Urban Design + Planning
Chicago, Illinois
Tel 312.930.9119
Dir  312.798.0298
Fax 312.930.9063
www.hntb.com<http://www.hntb.com/>
spgardner at hntb.com<mailto:spgardner at hntb.com>
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of rkoehler at excellandservices.com
Sent: Tuesday, February 25, 2014 8:02 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] PostGIS user interface
Hello,
Are there versions of PostGIS that can be used as a database input interface to capture land owner information for Land Acquisition companies? (Right-of-Way acquisition).  Our right of way company is looking for a GIS solution is which we can capture GPS coordinate data, land owner information easement documentation, notes, etc. and attach it to specific parcels, so that when we click on a parcel the data will pop up.  e.g. easement document.
Thank you,
Robert 651-210-9111<tel:651-210-9111>
Robert Koehler
Senior Siting and Land Rights Agent
Excel Land Services
rkoehler at excellandservices.com<mailto:rkoehler at excellandservices.com>
651-253-0003
[cid:image001.png at 01CF32F9.D61EC520]
This e-mail and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you are NOT the intended recipient and receive this communication, please delete this message and any attachments. Thank you.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140226/06b7f598/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140226/06b7f598/attachment.png>
