[postgis-users] postgis topology
Christophe Vergon christophevergon-girtec at orange.fr
Wed Jan 15 01:47:59 PST 2014
Hello,
Is st_geometryN(r.geomp,1)  a valid geometry ?
Ludovic Granjon a écrit :
> Hello (Bonjour Christophe)
> I don't use french cadastre, only specific archaelogical data.
> Thanks for this, I try but, I don't realy understand how worked
> topogeo_addpolygon.
> If I do :
> CREATE EXTENSION postgis;
> CREATE EXTENSION postgis_topology;
> SET search_path = topology,public;
> I import my layer with QGIS
> SELECT topology.CreateTopology('ec_topo', 27572);
> SELECT
> topology.AddTopoGeometryColumn('ec_topo','public','ec','topo_geom','POLYGON');
> DO $$DECLARE r record;
> BEGIN
>   FOR r IN SELECT * FROM ec LOOP
>     BEGIN
>     SELECT
> topology.TopoGeo_AddPolygon('ec_topo',st_geometryn(r.geom,1),1);
>     EXCEPTION
>       WHEN OTHERS THEN
>         RAISE WARNING 'Loading of record % failed: %', r.id, SQLERRM;
>     END;
>   END LOOP;
> END$$;
> I have :
> ATTENTION:  Loading of record 1 failed: la requête n'a pas de
> destination pour les données résultantes
> I don't know where I'm wrong
> If you have an idea
> Thanks
> Regards
> Ludovic
> PS : (si j'avais sur que c'était toi qui répondrait, j'aurai écrit sur
> nos forums francophone ;-) )
> Le 15/01/2014 08:25, Christophe Vergon a écrit :
>> Hello, (bonjour)
>> When you udpdate a topology by using a SET statement if a polygon
>> intersect an other you will have this error.
>> If you want to create a topology from polygons try to use the
>> topogeo_addpolygon function, the intersection between two polygons
>> will be a new face.
>> If, as I mean, you use a french survey "cadastre" data set, it's the
>> best way to do that.
>>> Hi all
>>> I try to import a polygon layer to postgis and build topology with
>>> tolerance.
>>> I try something like that
>>> SELECT CreateTopology('ec_topo2', 27572);
>>> SELECT AddTopoGeometryColumn('ec_topo2', 'public', 'ec',
>>> 'topogeom2', 'MULTIPOLYGON');
>>> UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
>>> But when I do that, I have
>>> ********** Erreur **********
>>> ERREUR: Spatial exception - geometry intersects edge 262
>>> État SQL :P0001
>>> Contexte : fonction PL/pgsql « topogeo_addlinestring », ligne 124 à
>>> affectation
>>> SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
>>> topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
>>> fonction PL/pgsql « topogeo_addpolygon », ligne 24 à affectation
>>> fonction PL/pgsql « totopogeom », ligne 112 à FOR sur des lignes de
>>> SELECT
>>> fonction PL/pgsql « totopogeom », ligne 94 à affectation
>>> I try to modify the tolerance parameter but it still doesn't work
>>> Have  you a solution for that ?
>>> Thanks a lot
>>> Regards
>>> Ludovic
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/47a1b435/attachment.html>
