[postgis-users] postgis topology
Ludovic Granjon ludovic.granjon at u-bourgogne.fr
Wed Jan 15 01:58:26 PST 2014
Hello
I think, I can do
SELECT st_geometryN(geom,1) FROM ec;
without error
I get
"POLYGON((504935.641400002 2310827.805,504952.193899997
2310825.6349,504964.4124 2310824.033,504964.191799998
2310823.56,504964.037199996 2310822.9832,504963.987400003
2310822.5117,504948.949900001 2310822.7941,504940.407399997
2310823.3589,504932.090300001 2310824.5769,504931.797399998
2310824.7718,504931.360100001 2310824.9757,504930.894100003
2310825.1006,504930.735399999 2310825.1239,504929.7368
2310825.2555,504929.7368 2310825.8138,504929.847599998
2310828.5646,504935.641400002 2310827.805))"
Thanks
Ludovic
Le 15/01/2014 10:47, Christophe Vergon a écrit :
> Hello,
> Is st_geometryN(r.geomp,1)  a valid geometry ?
> Ludovic Granjon a écrit :
>> Hello (Bonjour Christophe)
>> I don't use french cadastre, only specific archaelogical data.
>> Thanks for this, I try but, I don't realy understand how worked
>> topogeo_addpolygon.
>> If I do :
>> CREATE EXTENSION postgis;
>> CREATE EXTENSION postgis_topology;
>> SET search_path = topology,public;
>> I import my layer with QGIS
>> SELECT topology.CreateTopology('ec_topo', 27572);
>> SELECT
>> topology.AddTopoGeometryColumn('ec_topo','public','ec','topo_geom','POLYGON');
>> DO $$DECLARE r record;
>> BEGIN
>>   FOR r IN SELECT * FROM ec LOOP
>>     BEGIN
>>     SELECT
>> topology.TopoGeo_AddPolygon('ec_topo',st_geometryn(r.geom,1),1);
>>     EXCEPTION
>>       WHEN OTHERS THEN
>>         RAISE WARNING 'Loading of record % failed: %', r.id, SQLERRM;
>>     END;
>>   END LOOP;
>> END$$;
>> I have :
>> ATTENTION:  Loading of record 1 failed: la requête n'a pas de
>> destination pour les données résultantes
>> I don't know where I'm wrong
>> If you have an idea
>> Thanks
>> Regards
>> Ludovic
>> PS : (si j'avais sur que c'était toi qui répondrait, j'aurai écrit
>> sur nos forums francophone ;-) )
>> Le 15/01/2014 08:25, Christophe Vergon a écrit :
>>> Hello, (bonjour)
>>> When you udpdate a topology by using a SET statement if a polygon
>>> intersect an other you will have this error.
>>> If you want to create a topology from polygons try to use the
>>> topogeo_addpolygon function, the intersection between two polygons
>>> will be a new face.
>>> If, as I mean, you use a french survey "cadastre" data set, it's the
>>> best way to do that.
>>>> Hi all
>>>> I try to import a polygon layer to postgis and build topology with
>>>> tolerance.
>>>> I try something like that
>>>> SELECT CreateTopology('ec_topo2', 27572);
>>>> SELECT AddTopoGeometryColumn('ec_topo2', 'public', 'ec',
>>>> 'topogeom2', 'MULTIPOLYGON');
>>>> UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
>>>> But when I do that, I have
>>>> ********** Erreur **********
>>>> ERREUR: Spatial exception - geometry intersects edge 262
>>>> État SQL :P0001
>>>> Contexte : fonction PL/pgsql « topogeo_addlinestring », ligne 124 à
>>>> affectation
>>>> SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
>>>> topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as
>>>> foo"
>>>> fonction PL/pgsql « topogeo_addpolygon », ligne 24 à affectation
>>>> fonction PL/pgsql « totopogeom », ligne 112 à FOR sur des lignes de
>>>> SELECT
>>>> fonction PL/pgsql « totopogeom », ligne 94 à affectation
>>>> I try to modify the tolerance parameter but it still doesn't work
>>>> Have  you a solution for that ?
>>>> Thanks a lot
>>>> Regards
>>>> Ludovic
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/0279f7fd/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/0279f7fd/attachment.vcf>
