[postgis-users] Recording problems with PostGIS
Brice Bene brice.bene at gmail.com
Tue Mar 4 15:27:17 PST 2014
Finally I found the solution. The function set_rgeo_factory_for_column must
be added to each model with a link to PostGIS where you specify which
factory you are using.
example
: set_rgeo_factory_for_column(RGeo::Geographic.simple_mercator_factory.projection_factory)
Thank you for your help and your time.
*Brice.*
2014-03-04 21:42 GMT+01:00 benebrice <brice.bene at gmail.com>:
> I tried to create the database manually with the template and only after
> does the migrations. I check the value before being recorded and it is ok
> (I can obviously unproject the projection). But when it is stored, it
> cannot be unproject. The problem can come from 2 different points.
> The activerecord-postgis-adapter/rgeo-activerecord or PostGIS. I think
> Rails 4 is a possible reason of that.
> *Brice.*
> 2014-03-04 18:38 GMT+01:00 Dan Lyke [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005829&i=0>
>> On Tue, Mar 4, 2014 at 9:33 AM, benebrice <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005826&i=0>>
>> wrote:
>> > Thank you for your answer but unfortunately I had already tried this. I
>> did
>> > it again but still nothing. I used a similar configuration with a Rails
>> 3
>> > Application and Ruby 1.9.2 with PostiGIS 2. It was working.
>> Is there perhaps a way to dump the SQL that your Rails ORM is
>> generating? Seems to me like you've got a leaky abstraction layer
>> somewhere, the problem is likely in Rails, and without knowing how
>> Rails is going wrong we're just playing pin the tail on the donkey.
>> Dan
>> postgis-users mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005826&i=1>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005826.html
>>  To unsubscribe from Recording problems with PostGIS, click here.
>> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Recording problems with PostGIS<http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005829.html>
> Sent from the PostGIS - User mailing list archive<http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
> postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140305/1769b143/attachment.html>
