[postgis-users] Recording problems with PostGIS
Brice Bene brice.bene at gmail.com
Tue Mar 4 15:42:01 PST 2014
I did a mistake on my example. If someone use it in the futur, it is better
with a good example :
set_rgeo_factory_for_column(:position,
RGeo::Geographic.simple_mercator_factory.projection_factory)
where position is the name of the PostGIS column.
Regards,
*Brice.*
2014-03-05 0:27 GMT+01:00 Brice Bene <brice.bene at gmail.com>:
> Finally I found the solution. The function set_rgeo_factory_for_column
> must be added to each model with a link to PostGIS where you specify which
> factory you are using.
> example
> : set_rgeo_factory_for_column(RGeo::Geographic.simple_mercator_factory.projection_factory)
> Thank you for your help and your time.
> *Brice.*
> 2014-03-04 21:42 GMT+01:00 benebrice <brice.bene at gmail.com>:
>> I tried to create the database manually with the template and only after
>> does the migrations. I check the value before being recorded and it is ok
>> (I can obviously unproject the projection). But when it is stored, it
>> cannot be unproject. The problem can come from 2 different points.
>> The activerecord-postgis-adapter/rgeo-activerecord or PostGIS. I think
>> Rails 4 is a possible reason of that.
>> *Brice.*
>> 2014-03-04 18:38 GMT+01:00 Dan Lyke [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005829&i=0>
>>  On Tue, Mar 4, 2014 at 9:33 AM, benebrice <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005826&i=0>>
>>> wrote:
>>> > Thank you for your answer but unfortunately I had already tried this.
>>> I did
>>> > it again but still nothing. I used a similar configuration with a
>>> Rails 3
>>> > Application and Ruby 1.9.2 with PostiGIS 2. It was working.
>>> Is there perhaps a way to dump the SQL that your Rails ORM is
>>> generating? Seems to me like you've got a leaky abstraction layer
>>> somewhere, the problem is likely in Rails, and without knowing how
>>> Rails is going wrong we're just playing pin the tail on the donkey.
>>> Dan
>>> postgis-users mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005826&i=1>
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>  If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005826.html
>>>  To unsubscribe from Recording problems with PostGIS, click here.
>>> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Recording problems with PostGIS<http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005829.html>
>> Sent from the PostGIS - User mailing list archive<http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
>> postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140305/ac3627ef/attachment.html>
