[postgis-users] Recording problems with PostGIS
Margie Roswell mroswell at gmail.com
Tue Mar 4 16:11:30 PST 2014
Thanks for taking the time to post the solution. I look forward to using
Ruby with Postgis (ramping up on both!) and will come back to this thread.
Margie
http://FarmBillPrimer.org
http://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
http://www.ExcellentNutrition.org
http://www.packtpub.com/drupal-5-views-recipes/book
On Tue, Mar 4, 2014 at 6:42 PM, Brice Bene <brice.bene at gmail.com> wrote:
> I did a mistake on my example. If someone use it in the futur, it is
> better with a good example :
> set_rgeo_factory_for_column(:position,
> RGeo::Geographic.simple_mercator_factory.projection_factory)
> where position is the name of the PostGIS column.
> Regards,
> *Brice.*
> 2014-03-05 0:27 GMT+01:00 Brice Bene <brice.bene at gmail.com>:
> Finally I found the solution. The function set_rgeo_factory_for_column
>> must be added to each model with a link to PostGIS where you specify which
>> factory you are using.
>> example
>> : set_rgeo_factory_for_column(RGeo::Geographic.simple_mercator_factory.projection_factory)
>> Thank you for your help and your time.
>> *Brice.*
>> 2014-03-04 21:42 GMT+01:00 benebrice <brice.bene at gmail.com>:
>>>  I tried to create the database manually with the template and only
>>> after does the migrations. I check the value before being recorded and it
>>> is ok (I can obviously unproject the projection). But when it is stored, it
>>> cannot be unproject. The problem can come from 2 different points.
>>> The activerecord-postgis-adapter/rgeo-activerecord or PostGIS. I think
>>> Rails 4 is a possible reason of that.
>>> *Brice.*
>>> 2014-03-04 18:38 GMT+01:00 Dan Lyke [via PostGIS] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005829&i=0>
>>>  On Tue, Mar 4, 2014 at 9:33 AM, benebrice <[hidden email]<http://user/SendEmail.jtp?type=node&node=5005826&i=0>>
>>>> wrote:
>>>> > Thank you for your answer but unfortunately I had already tried this.
>>>> I did
>>>> > it again but still nothing. I used a similar configuration with a
>>>> Rails 3
>>>> > Application and Ruby 1.9.2 with PostiGIS 2. It was working.
>>>> Is there perhaps a way to dump the SQL that your Rails ORM is
>>>> generating? Seems to me like you've got a leaky abstraction layer
>>>> somewhere, the problem is likely in Rails, and without knowing how
>>>> Rails is going wrong we're just playing pin the tail on the donkey.
>>>> Dan
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005826&i=1>
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>  If you reply to this email, your message will be added to the
>>>> discussion below:
>>>> http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005826.html
>>>>  To unsubscribe from Recording problems with PostGIS, click here.
>>>> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>> View this message in context: Re: Recording problems with PostGIS<http://postgis.17.x6.nabble.com/Recording-problems-with-PostGIS-tp5005821p5005829.html>
>>> Sent from the PostGIS - User mailing list archive<http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html>at Nabble.com.
>>> postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140304/2e2307df/attachment.html>
