[postgis-users] Recent update to GDAL(?) broke PostGIS
Andy Colson andy at squeakycode.net
Wed Mar 12 14:42:13 PDT 2014
Sounds like the postgis package was uninstalled.  My debian foo is not
strong, but does something like this return anything:
dpkg -s postgis
or
dpkg-query -l 'postgis*'
-Andy
On 3/12/2014 2:38 PM, Jayson Gallardo wrote:
> That's the thing. I don't have a rtpostgis-2.x.so
> <http://rtpostgis-2.x.so> anywhere on my system. I'm pretty sure it was
> there before, because everything worked fine. And it may not even be
> GDAL. I checked with the server admin and that was the only thing that
> should have affected our setup.
> On Wed, Mar 12, 2014 at 2:11 PM, Andy Colson <andy at squeakycode.net
> <mailto:andy at squeakycode.net>> wrote:
>     On 3/12/2014 12:43 PM, Jayson Gallardo wrote:
>         A while ago, our Ubuntu server was updated. One of the updates
>         included
>         an update to gdal 1.10. Ever since then, our application no longer
>         works. PostGIS throws an error:
>              select postgis_full_version();
>              ERROR:  could not access file "$libdir/rtpostgis-2.0": No
>         such file
>              or directory
>              CONTEXT:  SQL statement "SELECT postgis_gdal_version()"
>              PL/pgSQL function "postgis_full_version" line 22 at SQL
>         statement
>     How about reverting back to the prior gdal?
>     I assume the problem is rtpostgis-2.1.so <http://rtpostgis-2.1.so>
>     is linked to gdal 1.9 or something.  You can check with "ldd
>     rtpostgis-2.1.so <http://rtpostgis-2.1.so>"
>     I dunno where your rtpostgis-2.1.so <http://rtpostgis-2.1.so> would
>     be.  Mine is in:
>       /usr/local/pgsql/lib/__postgresql
>     But your certainly wont be there.
>     -Andy
>     _________________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users
>     <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
