[postgis-users] Recent update to GDAL(?) broke PostGIS
Jayson Gallardo jaysontrades at gmail.com
Wed Mar 12 14:45:23 PDT 2014
This is what I get:
~$ dpkg -s postgis
Package: postgis
Status: install ok installed
Priority: optional
Section: misc
Installed-Size: 639
Maintainer: Debian GIS Project <pkg-grass-devel at lists.alioth.debian.org>
Architecture: amd64
Version: 2.0.3-2~precise4
Depends: libc6 (>= 2.14), libgdal1h (>= 1.9.0), libgeos-c1 (>= 3.3.8),
liblwgeom-2.0.3 (>= 2.0.0), libpq5
Suggests: postgresql-9.1-postgis-2.0
Description: Geographic objects support for PostgreSQL
 PostGIS adds support for geographic objects to the PostgreSQL
 object-relational database. In effect, PostGIS "spatially enables"
 the PostgreSQL server, allowing it to be used as a backend spatial
 database for geographic information systems (GIS), much like ESRI's
 SDE or Oracle's Spatial extension. PostGIS follows the OpenGIS
 "Simple Features Specification for SQL".
 This package contains the PostGIS userland binaries, common files.
Homepage: http://postgis.refractions.net/
I am carefully going through installing PostgreSQL 9.3 and then pg_upgrade
to see if I can migrate the data over...
On Wed, Mar 12, 2014 at 4:42 PM, Andy Colson <andy at squeakycode.net> wrote:
> Sounds like the postgis package was uninstalled.  My debian foo is not
> strong, but does something like this return anything:
> dpkg -s postgis
> or
> dpkg-query -l 'postgis*'
> -Andy
> On 3/12/2014 2:38 PM, Jayson Gallardo wrote:
>> That's the thing. I don't have a rtpostgis-2.x.so
>> <http://rtpostgis-2.x.so> anywhere on my system. I'm pretty sure it was
>> there before, because everything worked fine. And it may not even be
>> GDAL. I checked with the server admin and that was the only thing that
>> should have affected our setup.
>> On Wed, Mar 12, 2014 at 2:11 PM, Andy Colson <andy at squeakycode.net
>> <mailto:andy at squeakycode.net>> wrote:
>>     On 3/12/2014 12:43 PM, Jayson Gallardo wrote:
>>         A while ago, our Ubuntu server was updated. One of the updates
>>         included
>>         an update to gdal 1.10. Ever since then, our application no longer
>>         works. PostGIS throws an error:
>>              select postgis_full_version();
>>              ERROR:  could not access file "$libdir/rtpostgis-2.0": No
>>         such file
>>              or directory
>>              CONTEXT:  SQL statement "SELECT postgis_gdal_version()"
>>              PL/pgSQL function "postgis_full_version" line 22 at SQL
>>         statement
>>     How about reverting back to the prior gdal?
>>     I assume the problem is rtpostgis-2.1.so <http://rtpostgis-2.1.so>
>>     is linked to gdal 1.9 or something.  You can check with "ldd
>>     rtpostgis-2.1.so <http://rtpostgis-2.1.so>"
>>     I dunno where your rtpostgis-2.1.so <http://rtpostgis-2.1.so> would
>>     be.  Mine is in:
>>       /usr/local/pgsql/lib/__postgresql
>>     But your certainly wont be there.
>>     -Andy
>>     _________________________________________________
>>     postgis-users mailing list
>>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>>     http://lists.osgeo.org/cgi-__bin/mailman/listinfo/postgis-__users
>>     <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140312/736b684d/attachment.html>
