[postgis-users] SRID not matching error
Åsmund Tokheim asmundto at gmail.com
Wed May 21 16:45:46 PDT 2014
Hi
It seems like you transformed the polygon used in the st_intersects
function, but the polygon used in the st_clip function still has the 3857
srid.
Åsmund
On Thu, May 22, 2014 at 1:04 AM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
> I was finally able to restore my database dump today. However, upon
> testing, I get this error:
> production=# SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
> ST_GeomFromText('POLYGON((-10366992.073461 5117898.5805526,-10366635.506271
> 5117898.5805526,-10366635.506271 5118206.0551587,-10366992.073461
> 5118206.0551587,-10366992.073461 5117898.5805526))',3857)),'GTiff') FROM
> "dem_elevation" WHERE ST_Intersects(rast,
> ST_Transform(ST_GeomFromText('POLYGON((-10366992.073461
> 5117898.5805526,-10366635.506271 5117898.5805526,-10366635.506271
> 5118206.0551587,-10366992.073461 5118206.0551587,-10366992.073461
> 5117898.5805526))',3857),4269));
> NOTICE:  Geometry provided does not have the same SRID as the raster.
> Returning NULL
> However, all my DEMs are in the raster with SRID 4269. My DEMs have been
> partitioned however, but the restore should have restored all that back
> into place, right?
> This is what I have for dem_elevation in pgAdmin:
> -- Table: dem_elevation
> -- DROP TABLE dem_elevation;
> CREATE TABLE dem_elevation
>   rid integer NOT NULL,
>   rast raster,
>   CONSTRAINT dem_elevation_pkey PRIMARY KEY (rid)
> WITH (
>   OIDS=FALSE
> ALTER TABLE dem_elevation
>   OWNER TO postgres;
> GRANT ALL ON TABLE dem_elevation TO postgres;
> GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation TO postgis_reader;
> And one of the dependents:
> -- Table: dem_elevation_n33w090
> -- DROP TABLE dem_elevation_n33w090;
> CREATE TABLE dem_elevation_n33w090
>   rid serial NOT NULL,
>   rast raster,
>   CONSTRAINT dem_elevation_n33w090_pkey PRIMARY KEY (rid),
>   CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 50),
>   CONSTRAINT enforce_max_extent_rast CHECK
> (st_coveredby(st_convexhull(rast),
> '0103000020AD1000000100000005000000863D2B1A098056C03B126100F5FE3F40863D2B1A098056C09578563412804040CA451840BD3F56C09578563412804040CA451840BD3F56C03B126100F5FE3F40863D2B1A098056C03B126100F5FE3F40'::geometry)),
>   CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
>   CONSTRAINT enforce_out_db_rast CHECK (_raster_constraint_out_db(rast) =
> '{f}'::boolean[]),
>   CONSTRAINT enforce_pixel_types_rast CHECK
> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>   CONSTRAINT enforce_same_alignment_rast CHECK (st_samealignment(rast,
> '010000000097C6CEA0C845183F97C6CEA0C84518BF863D2B1A098056C0957856341280404000000000000000000000000000000000AD10000001000100'::raster)),
>   CONSTRAINT enforce_scalex_rast CHECK (st_scalex(rast)::numeric(16,10) =
> 0.000092592592593::numeric(16,10)),
>   CONSTRAINT enforce_scaley_rast CHECK (st_scaley(rast)::numeric(16,10) =
> (-0.000092592592593)::numeric(16,10)),
>   CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>   CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 50)
> INHERITS (dem_elevation)
> WITH (
>   OIDS=FALSE
> ALTER TABLE dem_elevation_n33w090
>   OWNER TO postgres;
> GRANT ALL ON TABLE dem_elevation_n33w090 TO postgres;
> GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation_n33w090 TO
> postgis_reader;
> -- Index: dem_elevation_n33w090_rast_gist
> -- DROP INDEX dem_elevation_n33w090_rast_gist;
> CREATE INDEX dem_elevation_n33w090_rast_gist
>   ON dem_elevation_n33w090
>   USING gist
>   (st_convexhull(rast));
> Thanks for your help in advance,
> Jayson
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140522/3861d414/attachment.html>
