[postgis-users] SRID not matching error
Jayson Gallardo jaysontrades at gmail.com
Thu May 22 08:14:02 PDT 2014
Well, the thing is, that's how it's been for the last year and has worked
fine. The difference now is that our server was rebuilt from scratch and I
had to reload a dump of our database. The other difference is that the
previous database was on PostgreSQL 9.1, and now we're on 9.3.
On Wed, May 21, 2014 at 6:45 PM, Åsmund Tokheim <asmundto at gmail.com> wrote:
> Hi
> It seems like you transformed the polygon used in the st_intersects
> function, but the polygon used in the st_clip function still has the 3857
> srid.
> Åsmund
> On Thu, May 22, 2014 at 1:04 AM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>> I was finally able to restore my database dump today. However, upon
>> testing, I get this error:
>> production=# SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
>> ST_GeomFromText('POLYGON((-10366992.073461 5117898.5805526,-10366635.506271
>> 5117898.5805526,-10366635.506271 5118206.0551587,-10366992.073461
>> 5118206.0551587,-10366992.073461 5117898.5805526))',3857)),'GTiff') FROM
>> "dem_elevation" WHERE ST_Intersects(rast,
>> ST_Transform(ST_GeomFromText('POLYGON((-10366992.073461
>> 5117898.5805526,-10366635.506271 5117898.5805526,-10366635.506271
>> 5118206.0551587,-10366992.073461 5118206.0551587,-10366992.073461
>> 5117898.5805526))',3857),4269));
>> NOTICE:  Geometry provided does not have the same SRID as the raster.
>> Returning NULL
>> However, all my DEMs are in the raster with SRID 4269. My DEMs have been
>> partitioned however, but the restore should have restored all that back
>> into place, right?
>> This is what I have for dem_elevation in pgAdmin:
>> -- Table: dem_elevation
>> -- DROP TABLE dem_elevation;
>> CREATE TABLE dem_elevation
>>   rid integer NOT NULL,
>>   rast raster,
>>   CONSTRAINT dem_elevation_pkey PRIMARY KEY (rid)
>> WITH (
>>   OIDS=FALSE
>> ALTER TABLE dem_elevation
>>   OWNER TO postgres;
>> GRANT ALL ON TABLE dem_elevation TO postgres;
>> GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation TO
>> postgis_reader;
>> And one of the dependents:
>> -- Table: dem_elevation_n33w090
>> -- DROP TABLE dem_elevation_n33w090;
>> CREATE TABLE dem_elevation_n33w090
>>   rid serial NOT NULL,
>>   rast raster,
>>   CONSTRAINT dem_elevation_n33w090_pkey PRIMARY KEY (rid),
>>   CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 50),
>>   CONSTRAINT enforce_max_extent_rast CHECK
>> (st_coveredby(st_convexhull(rast),
>> '0103000020AD1000000100000005000000863D2B1A098056C03B126100F5FE3F40863D2B1A098056C09578563412804040CA451840BD3F56C09578563412804040CA451840BD3F56C03B126100F5FE3F40863D2B1A098056C03B126100F5FE3F40'::geometry)),
>>   CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
>>   CONSTRAINT enforce_out_db_rast CHECK (_raster_constraint_out_db(rast) =
>> '{f}'::boolean[]),
>>   CONSTRAINT enforce_pixel_types_rast CHECK
>> (_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
>>   CONSTRAINT enforce_same_alignment_rast CHECK (st_samealignment(rast,
>> '010000000097C6CEA0C845183F97C6CEA0C84518BF863D2B1A098056C0957856341280404000000000000000000000000000000000AD10000001000100'::raster)),
>>   CONSTRAINT enforce_scalex_rast CHECK (st_scalex(rast)::numeric(16,10) =
>> 0.000092592592593::numeric(16,10)),
>>   CONSTRAINT enforce_scaley_rast CHECK (st_scaley(rast)::numeric(16,10) =
>> (-0.000092592592593)::numeric(16,10)),
>>   CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
>>   CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 50)
>> INHERITS (dem_elevation)
>> WITH (
>>   OIDS=FALSE
>> ALTER TABLE dem_elevation_n33w090
>>   OWNER TO postgres;
>> GRANT ALL ON TABLE dem_elevation_n33w090 TO postgres;
>> GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation_n33w090 TO
>> postgis_reader;
>> -- Index: dem_elevation_n33w090_rast_gist
>> -- DROP INDEX dem_elevation_n33w090_rast_gist;
>> CREATE INDEX dem_elevation_n33w090_rast_gist
>>   ON dem_elevation_n33w090
>>   USING gist
>>   (st_convexhull(rast));
>>  Thanks for your help in advance,
>> Jayson
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140522/56e42db5/attachment.html>
