[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Oliver Burgfeld oliver.burgfeld at gmail.com
Tue Nov 25 09:10:53 PST 2014
Ops, perfectly working now, thank you!
Am Dienstag, 25. November 2014 17:56:53 UTC+1 schrieb Brent Wood:
> My fault, you also need to select these in the final select, try:
> WITH multis AS (
>                 SELECT id, status,* min(timestamp) as time_start,
> max(timestamp) as time_end, *ST_MakeLine( point_geom ORDER BY timestamp) AS
> mylines
>                 FROM your_table
> GROUP BY id, status
> SELECT id, status,* time_start, time_end*, (ST_Dump(mylines)).geom
> Cheers,
>   Brent
>  *From:* Oliver Burgfeld <oliver.... at gmail.com <javascript:>>
> *To:* postgi... at googlegroups.com <javascript:>
> *Cc:* postgi... at lists.osgeo.org <javascript:>; pcr... at pcreso.com
> <javascript:>; postgi... at lists.osgeo.org <javascript:>; pcr... at pcreso.com
> <javascript:>
> *Sent:* Wednesday, November 26, 2014 5:48 AM
> *Subject:* Re: [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
> I also tried that and it works but it does not give me those two columns
> in my new table. There are only id and status inside.
> Am Dienstag, 25. November 2014 17:39:21 UTC+1 schrieb Brent Wood:
> as in my previous reply, I figured that would be useful...
> WITH multis AS (
> mylines
>                 FROM your_table
> GROUP BY id, status
> SELECT id, status, (ST_Dump(mylines)).geom
> FROM multisBrent Wood
>  *From:* Oliver Burgfeld <oliver.... at gmail.com>
> *Cc:* pcr... at pcreso.com; postgi... at lists.osgeo.org;
> postgi... at lists.osgeo.org; remi... at gmail.com
> *Sent:* Wednesday, November 26, 2014 5:10 AM
> points[PostGIS]
> Thank you and all the others who were answering :)
> I tried that and it seems that its working. Nevertheless I only tried it
> with a small part of my data (round about 1 million rows out of ~500
> million) but if it's working now, it should also work with the whole
> dataset.
> Is there a way to also include the time_field into the result? I created a
> new table with this statement given but there are only two columns
> (vehicleid and status) included.
> I know thats logical because I only included those two into my select
> clause but it would be great to not only order by time but also have a time
> column in my table.
> For example:
> vehicleid | status | time_start | time_end
> I hope its understandable and not to mixed up...
> Thanks!
> Am Dienstag, 25. November 2014 16:06:33 UTC+1 schrieb Rémi Cura:
> Hey, a small correction :
> ST_MakeLine is already an aggregate, and you may want to enforce the order
> inside the aggregate (see at the end).
> Another interesting point is the possiblity to pu somehting in the M value
> of each point of the line, for instance the time.
> This comes very handy when you want to extrat parts of the lines.
> So for instance for the first proposition :
> WITH multis AS (
>                 SELECT id, status,* ST_MakeLine( point_**geom ORDER BY
> time_field) *AS mylines
>                 FROM your_table
> GROUP BY id, status
> FROM multis
> Cheers,
> Rémi-c
> 2014-11-25 9:53 GMT+01:00 Brent Wood <pcr... at pcreso.com>:
> or automatically get the start & end times for each trackline in the
> record like this:
> WITH multis AS (
>                 SELECT id, min(time_field) AS time_start, max(time_field)
> as time_end, status, ST_MakeLine(array_agg(point_ geom )) AS mylines
>                 FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis;
> Cheers,
>    Brent Wood
>  *From:* Hugues François <hugues.... at irstea.fr>
> *To:* PostGIS Users Discussion <postgi... at lists.osgeo.org >
> *Sent:* Tuesday, November 25, 2014 8:13 PM
> points[PostGIS]
> Hello,
> In your case I would have try to make multilines for each taxi and each
> status (i.e. two multi by taxi) and then dump them into  simple
> linestrings. All in a query that may look like this assuming you have a
> taxi id field:
> WITH multis AS (
>                 SELECT id, status, ST_MakeLine(array_agg(point_ geom )) AS
> mylines
>                 FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis
> You may want to add a time reference to your lines. To do this, you can
> add an extraction from your timestamp field (e.g. day or month) and add it
> into the WITH and to the group by clause.
> Hugues.
> *De :* postgis-us... at lists. osgeo.org [mailto:postgis-us...@
> lists.osgeo.org] *De la part de* Oliver Burgfeld
> *Envoyé :* mardi 25 novembre 2014 07:09
> *À :* postgi... at lists.osgeo.org
> *Objet :* [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
> Hi,
> I have millions of points in a PostGIS database containing taxi gps
> tracks. Now I want to create lines from these points by vehicleid and
> ordered by timestamp. But, and that's my problem right now, at first I want
> to include every column of my point table into the "line table" and I also
> need to intersect those lines at specific points.
> I have one column representing the "taxi_is_occupied" status with 0 or 1.
> What I want now is to create lines which are divided every time this
> status changes. In the end I need lines which show the path of every taxi
> over time, divided every time the status of the car changes so that I can
> query all lines where the taxi is occupied, for example.
> What do I have to use therefore? I know that there is the ST_MakeLines
> tool existing in PostGIS, but as I am a new PostGIS user... I do not know
> exactly how to use it to get the results I need.
> Thanks a lot
> ______________________________ _________________
> postgis-users mailing list
> http://lists.osgeo.org/cgi- bin/mailman/listinfo/postgis- users
> <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/d7a7aedc/attachment-0001.html>
