[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Roxanne Reid-Bennett rox at tara-lu.com
Tue Nov 25 10:16:53 PST 2014
On 11/25/2014 11:48 AM, Oliver Burgfeld wrote:
> I also tried that and it works but it does not give me those two
> columns in my new table. There are only id and status inside.
 From the quer below change
SELECT id, status, (ST_Dump(mylines)).geom
to
SELECT id, status, (ST_Dump(mylines)).geom, time_start, time_end
Something to keep an eye out for... Depending upon your version of
PostGIS and the underlying libraries, because we were working with an
older version of the underlying libraries, I don't know if this is still
a potential issue. We ran into issues with "stacked" points (2 GPS
points with the same coordinates), and GPS drift causing issues with the
linestrings being pretty goofy (jagged points in the linestring that
were clearly NOT what the vehicle did). We wrote cleanup scripts to take
care of those issues (that are still in place).  I've not taken time to
revisit the library routines to see if they now handle those conditions
cleanly.
Roxanne
> Am Dienstag, 25. November 2014 17:39:21 UTC+1 schrieb Brent Wood:
>     as in my previous reply, I figured that would be useful...
>     WITH multis AS (
>     SELECT id, status,*min(timestamp) as time_start, max(timestamp) as
>     time_end, *ST_MakeLine( point_geom ORDER BY timestamp) AS mylines
>     FROM your_table
>     GROUP BY id, status
>     FROM multisBrent Wood
>     *From:* Oliver Burgfeld <oliver.... at gmail.com <javascript:>>
>     *To:* postgi... at googlegroups.com <javascript:>
>     *Cc:* pcr... at pcreso.com <javascript:>; postgi... at lists.osgeo.org
>     <javascript:>; postgi... at lists.osgeo.org <javascript:>;
>     remi... at gmail.com <javascript:>
>     *Sent:* Wednesday, November 26, 2014 5:10 AM
>     *Subject:* Re: [postgis-users] Creating trajectory/lines from
>     Thank you and all the others who were answering :)
>     I tried that and it seems that its working. Nevertheless I only
>     tried it with a small part of my data (round about 1 million rows
>     out of ~500 million) but if it's working now, it should also work
>     with the whole dataset.
>     Is there a way to also include the time_field into the result? I
>     created a new table with this statement given but there are only
>     two columns (vehicleid and status) included.
>     I know thats logical because I only included those two into my
>     select clause but it would be great to not only order by time but
>     also have a time column in my table.
>     For example:
>     vehicleid | status | time_start | time_end
>     I hope its understandable and not to mixed up...
>     Thanks!
>     Am Dienstag, 25. November 2014 16:06:33 UTC+1 schrieb Rémi Cura:
>         Hey, a small correction :
>         ST_MakeLine is already an aggregate, and you may want to
>         enforce the order inside the aggregate (see at the end).
>         Another interesting point is the possiblity to pu somehting in
>         the M value of each point of the line, for instance the time.
>         This comes very handy when you want to extrat parts of the lines.
>         So for instance for the first proposition :
>         WITH multis AS (
>                         SELECT id, status,*ST_MakeLine( point_**geom
>         ORDER BY time_field) *AS mylines
>                         FROM your_table
>         GROUP BY id, status
>         FROM multis
>         Cheers,
>         Rémi-c
>         2014-11-25 9:53 GMT+01:00 Brent Wood <pcr... at pcreso.com>:
>             or automatically get the start & end times for each
>             trackline in the record like this:
>             WITH multis AS (
>             SELECT id, min(time_field) AS time_start, max(time_field)
>             as time_end, status, ST_MakeLine(array_agg(point_ geom ))
>             AS mylines
>             FROM your_table
>             GROUP BY id, status
>             ORDER BY time_field
>             FROM multis;
>             Cheers,
>                Brent Wood
>             *From:* Hugues François <hugues.... at irstea.fr>
>             *To:* PostGIS Users Discussion <postgi... at lists.osgeo.org >
>             *Sent:* Tuesday, November 25, 2014 8:13 PM
>             Hello,
>             In your case I would have try to make multilines for each
>             taxi and each status (i.e. two multi by taxi) and then
>             dump them into simple linestrings. All in a query that may
>             look like this assuming you have a taxi id field:
>             WITH multis AS (
>             SELECT id, status, ST_MakeLine(array_agg(point_ geom )) AS
>             mylines
>             FROM your_table
>             GROUP BY id, status
>             ORDER BY time_field
>             FROM multis
>             You may want to add a time reference to your lines. To do
>             this, you can add an extraction from your timestamp field
>             (e.g. day or month) and add it into the WITH and to the
>             group by clause.
>             Hugues.
>             *De :*postgis-us... at lists. osgeo.org
>             [mailto:postgis-us...@ lists.osgeo.org] *De la part de*
>             Oliver Burgfeld
>             *Envoyé :* mardi 25 novembre 2014 07:09
>             *À :* postgi... at lists.osgeo.org
>             *Objet :* [postgis-users] Creating trajectory/lines from
>             Hi,
>             I have millions of points in a PostGIS database containing
>             taxi gps tracks. Now I want to create lines from these
>             points by vehicleid and ordered by timestamp. But, and
>             that's my problem right now, at first I want to include
>             every column of my point table into the "line table" and I
>             also need to intersect those lines at specific points.
>             I have one column representing the "taxi_is_occupied"
>             status with 0 or 1.
>             What I want now is to create lines which are divided every
>             time this status changes. In the end I need lines which
>             show the path of every taxi over time, divided every time
>             the status of the car changes so that I can query all
>             lines where the taxi is occupied, for example.
>             What do I have to use therefore? I know that there is the
>             ST_MakeLines tool existing in PostGIS, but as I am a new
>             PostGIS user... I do not know exactly how to use it to get
>             the results I need.
>             Thanks a lot
>             ______________________________ _________________
>             postgis-users mailing list
>             http://lists.osgeo.org/cgi- bin/mailman/listinfo/postgis-
>             users
>             <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
>             users
> postgis-users at lists.osgeo.org
[At other schools] I think the most common fault in general is to teach students how to pass exams instead of teaching them the science.
Donald Knuth
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/b5c51ce8/attachment.html>
