[postgis-users] PostGIS 2.1 CREATE EXTENSION vs Loading postgis.sql and spatial_ref_sys.sql
Puthick Hok hputhick at gmail.com
Tue Feb 3 20:41:13 PST 2015
I was given a schema whose tables contain primary key fields named just
'id'. For example, layer table has 'id' field as it primary key and
'name' as a normal field. I already know that these two names are not
good name because they are reserved words used in many places like they
break XML, for example.
I use Perl DBI to connect to Postgresql. If I create the postgis
database using 'CREATE EXTENSION' method, Perl DBI returns 'layer_id' as
the primary key of my layer table. If I create the postgis database
using the old incompatible way of loading postgis.sql and
spatial_ref_sys.sql, Perl DBI returns 'id' as it is named as the primary
Can anyone explain the details? My postgresql is 9.3.5 and postgis is
2.1. I need an excuse for my broken code just because the database is
created using a different method.
Thanks,
Puthick
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150204/4e258917/attachment.html>
