[postgis-users] PostGIS 2.1 CREATE EXTENSION vs Loading postgis.sql and spatial_ref_sys.sql
BladeOfLight16 bladeoflight16 at gmail.com
Tue Feb 3 20:54:40 PST 2015
On Tue, Feb 3, 2015 at 11:41 PM, Puthick Hok <hputhick at gmail.com> wrote:
>   I use Perl DBI to connect to Postgresql. If I create the postgis
> database using 'CREATE EXTENSION' method, Perl DBI returns 'layer_id' as
> the primary key of my layer table. If I create the postgis database using
> the old incompatible way of loading postgis.sql and spatial_ref_sys.sql,
> Perl DBI returns 'id' as it is named as the primary key of my layer table.
That doesn't make sense. I'm pretty sure that neither CREATE EXTENSION nor
running postgis.sql and spatial_ref_sys.sql would affect the primary key of
an existing table. Most likely, you're running some other SQL of your own,
and you have something weird going on in that. How are you creating your
"layer table"?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150203/01ecf951/attachment.html>
