[postgis-users] postgis-users Digest, Vol 163, Issue 11
Birgit Laggner birgit.laggner at ti.bund.de
Mon Sep 28 23:54:47 PDT 2015
Hi Bob,
you are right. What a mess... Now I tried using the quote_literal()
which worked for the select statement:
declare @v;
set @v = '1';
SELECT * from gradeschools_aroo where gradecode = quote_literal(@v);
So, it all comes down to Davids suggestion from the beginning. But the
quote_literal() won't work if not used in a SELECT statement.
Regards,
Birgit
Am 28.09.2015 um 22:01 schrieb Bistrais, Bob:
> Hello Birgit,
> I tried triple quoting my value as suggested.  This works in the simple script.  But when I try using it in a Select statement, it fails:
> declare @v;
> set @v = '''1''';
> SELECT * from gradeschools_aroo where gradecode = @v;
> SELECT * from gradeschools_aroo where gradecode = ''1''
>              ERROR:  syntax error at or near "1"
> -----Original Message-----
> From: Birgit Laggner [mailto:birgit.laggner at ti.bund.de]
> Sent: Monday, September 28, 2015 4:02 AM
> To: Bistrais, Bob; postgis-users at lists.osgeo.org; david.fawcett at gmail.com
> Subject: Re: postgis-users Digest, Vol 163, Issue 11
> Hi Bob,
> now, I understand your problem. My suggestion would be to triple the single quotation marks as in the small example below:
> declare @v;
> set @v = '''1''';
> print @v;
> I hope this works with your pgscript somehow...
> Regards,
> Birgit
> Am 25.09.2015 um 14:19 schrieb Bistrais, Bob:
>> Hi Birgit and David,
>> Many thanks for your replies.  I actually tried what you had suggested.  Quoting the variable as '@myvariable' caused the liteal string, @myvariable, to be passed.  I also tried casting, but the variable still got passed as an integer, without quots, causing an error.
>> In order to make it work, I created another field which is an integer field.  I populated the new field with the appropriate integer values.  This worked, but I would still be interested in finding a way to pas numeric characters as text.
>> ________________________________________
>> From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of postgis-users-request at lists.osgeo.org [postgis-users-request at lists.osgeo.org]
>> Sent: Thursday, September 24, 2015 3:00 PM
>> To: postgis-users at lists.osgeo.org
>> Subject: postgis-users Digest, Vol 163, Issue 11
>> Send postgis-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>>           http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>           postgis-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of postgis-users digest..."
>> Today's Topics:
>>      1. Using string variables with PGScript (Bistrais, Bob)
>>      2. Re: Using string variables with PGScript (David Fawcett)
>>      3. Re: Using string variables with PGScript (Birgit Laggner)
>> Message: 1
>> Date: Wed, 23 Sep 2015 21:26:32 +0000
>> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>> To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
>> Subject: [postgis-users] Using string variables with PGScript
>> Message-ID:
>>           <D655A37D8BC306438F87579A672E3D107AEE9906 at OIT-TEAQEXMBX01.som.w2k.state.me.us>
>> Content-Type: text/plain; charset="us-ascii"
>> I am having trouble using a variable in a Select statement, using PGScript.  I am trying to define a string variable, then use it in the Select statement.  Something like this:
>> DECLARE @MYSTRING;
>> SET @MYSTRING = CAST(@REC[0]['mycode'] AS STRING);   -- at REC was set from a previous select
>> SELECT * from mytable where myfield = @MYSTRING;
>> -The variable is not quoted, so the select statement fails.  How do I get the string variable to be enclosed in quotes?
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/43f67cbd/attachment-0001.html>
>> Message: 2
>> Date: Wed, 23 Sep 2015 20:43:30 -0500
>> From: David Fawcett <david.fawcett at gmail.com>
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> Subject: Re: [postgis-users] Using string variables with PGScript
>> Message-ID:
>>           <CAF7K3b8x=jEBPMWTa_B4hUOSNK=45tE0nM1xcjyS9wWRmoUodQ at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Bob,
>> I haven't ever used PGScript, but I wonder one of the postgres quote
>> functions found on this page might work:
>> http://www.postgresql.org/docs/9.1/static/functions-string.html
>> I would try quote_literal()
>> David.
>> On Wed, Sep 23, 2015 at 4:26 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
>>> DECLARE @MYSTRING;
>>> previous select
>> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150923/a0ce2539/attachment-0001.html>
>> Message: 3
>> Date: Thu, 24 Sep 2015 15:22:42 +0200
>> From: Birgit Laggner <birgit.laggner at ti.bund.de>
>> Message-ID: <5603F922.4090801 at ti.bund.de>
>> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
>> Hi Bob,
>> I would recommend something as simple as
>> SELECT * from mytable where myfield = '@MYSTRING';
>> I tried using a string variable in a PGScript once, too, and if I
>> remember correctly, quote_literal() did not work.
>> Good luck and regards,
>> Birgit
>> Am 24.09.2015 um 03:43 schrieb David Fawcett:
>>> Bob,
>>> David.
>>>       DECLARE @MYSTRING;
>>>       postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150924/8ed2df10/attachment-0001.html>
>> End of postgis-users Digest, Vol 163, Issue 11
