[postgis-users] CREATE EXTENSION postgis fails with "ERROR: could not load library "/usr/pgsql-9.5/lib/postgis-2.2.so": /usr/pgsql-9.5/lib/postgis-2.2.so: undefined symbol: GEOSClipByRect"
Paul Ramsey pramsey at cleverelephant.ca
Fri Jan 15 06:35:47 PST 2016
Thanks for confirming, I've notified the pgdg packager.
P
On Fri, Jan 15, 2016 at 6:25 AM, Paul Edwards <pjfingers at gmail.com> wrote:
> Sorry for the spam, but as you suspected:
>  yum deplist postgis2_95
> ****bunch of dependencies****
> dependency: geos >= 3.4.2
> On Friday, January 15, 2016 at 9:20:33 AM UTC-5, Paul Edwards wrote:
>> Was debugging the exact issue yesterday. Updating GEOS to 3.5 did the
>> trick for me. This is the version of geos provided for in the pgdg95 repo.
>> On Thursday, January 14, 2016 at 9:13:13 AM UTC-5, Paul Ramsey wrote:
>>> Check the versions of the GEOS rpm you have installed, and also check
>>> the "requires" declarations for the postgis rpm. Probably you'll find
>>> the GEOS rpm is version 3.4 and that the postgis rpm doesn't declare a
>>> dependency for geos 3.5. See if you can track down a GEOS 3.5 rpm.
>>> P
>>> On Thu, Jan 14, 2016 at 2:04 AM, Moti Umansky <Moti.U... at ness.com> wrote:
>>> > I have reproduced the issue when installing with yum install from the
>>> > internet.
>>> > I think there is something wrong with the last version installation on
>>> > Oracle Linux (or Red Hat).
>>> > Has anyone succeeded to install the last version on Oracle Linux or Red
>>> > Hat?
>>> > Thanks,
>>> > Moti
>>> > From: Moti Umansky
>>> > Sent: יום א 10 ינואר 2016 18:08
>>> > To: 'postgi... at lists.osgeo.org'
>>> > Subject: CREATE EXTENSION postgis fails with "ERROR: could not load
>>> > library
>>> > Hi
>>> > I'm trying to install the new 9.5 Postgres version with Postgis 2.2
>>> > (downloaded from
>>> > https://download.postgresql.org/pub/repos/yum/9.5/redhat/rhel-6.7-x86_64/)
>>> > When I issue "CREATE EXTENSION postgis", I'm getting :
>>> > OS : Oracle Linux 6U7
>>> > Postgres version : "PostgreSQL 9.5.0 on x86_64-pc-linux-gnu, compiled
>>> > by gcc
>>> > (GCC) 4.4.7 20120313 (Red Hat 4.4.7-16), 64-bit"
>>> > I have tried to reproduce the issue on Postgres 9.4.5 downloaded from
>>> > https://download.postgresql.org/pub/repos/yum/9.4/redhat/rhel-6.7-x86_64.
>>> > The issue was not reproduced.
>>> > Thanks,
>>> > Moti
>>> > ____________________________
>>> > Powered By Office365
>>> > The information contained in this communication is intended solely for
>>> > the
>>> > use of the individual or entity to whom it is addressed and others
>>> > authorized to receive it.
>>> > It may contain confidential or legally privileged information.
>>> > If you are not the intended recipient you are hereby notified that any
>>> > disclosure, copying, distribution or taking any action in reliance on
>>> > the
>>> > contents of this information is strictly prohibited and may be
>>> > unlawful.
>>> > If you have received this communication in error, please notify us
>>> > immediately by forwarding this email to Mail... at ness.com and then
>>> > delete
>>> > it from your system.
>>> > Ness technologies is neither liable for the proper and complete
>>> > transmission
>>> > of the information contained in this communication nor for any delay in
>>> > its
>>> > receipt.
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > http://lists.osgeo.org/mailman/listinfo/postgis-users
