[postgis-users] compiling from source code
Regina Obe lr at pcorp.us
Fri Jul 7 15:33:03 PDT 2017
Okay I just got an irc note from Even Roualt.  He is running Ubuntu 16.04 and gcc 5.4  and had no issue running
sh autogen.sh
./configure
So doesn't seem like it's a newer gcc issue unless if its 5.3 specific.
I'm suspecting something with brew,  MacOS, or tool chain like autoconf.
What does:
autoconf --version
Return?
I get
autoconf (GNU Autoconf) 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+/Autoconf: GNU GPL version 3 or later
Thanks,
Regina
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandeep Gupta
Sent: Friday, July 07, 2017 6:18 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] compiling from source code
Hi Regina,
 Here is the output for gcc -v (install gcc from linuxbrew, which port of brew package manager of macOS):
Reading specs from
/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0/specs
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: ../configure
--prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
--enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5 --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
--with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
--with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
--with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.3.0'
--with-bugurl=https://github.com/Homebrew/homebrew/issues
--enable-plugin --disable-nls --disable-multilib Thread model: posix gcc version 5.3.0 (Homebrew gcc 5.3.0)
Thanks.
sandeep
On Fri, Jul 7, 2017 at 5:52 PM, Regina Obe <lr at pcorp.us> wrote:
> Steve and Sandeep,
> Can you try gcc -v instead and let me know what that outputs?
> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1  and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
> However if I do gcc -V, I get an error on her too, so that's not the issue here:
> gcc: error: unrecognized command line option  ?~-V ?T
> gcc: fatal error: no input files
> compilation terminated.
> However, lower case -v  (which is what I think configure uses, works just fine).
> gcc -v
> outputs:
> Using built-in specs.
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
> Target: x86_64-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Debian
> 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
> --prefix=/usr --program-suffix=-5 --enable-shared --ena
> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
> --with-arch-directory=amd64
> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
> --enable-multiarch --with-arch-32=i586 --with-abi=m64
> --with-multilib-list=m32,m64,mx32 --enable-m Thread model: posix gcc
> version 5.2.1 20151010 (Debian 5.2.1-22)
> I'm not sure where Sandeep's   gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
> Thanks,
> Regina
> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
> I get the same error running on Ubuntu 16.04 with:
> $ gcc -V
> gcc: error: unrecognized command line option  -V
> Looks like the option should be --version $ gcc --version gcc (Ubuntu
> 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 Copyright (C) 2015 Free
> This is free software; see the source for copying conditions.  There
> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> -Steve
> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
> Hi,
> I am using gcc version 5.3 to compile postgis on Fedora.
> The compile  fails at the configure step.
> I get the error:
> configure: error: C preprocessor "gcc" fails sanity check See
> `config.log' for more details
> The relevant line in config.log:
> configure:3031: gcc -v >&5
> Reading specs from
> ux-gnu/5.3.0/specs
> COLLECT_GCC=gcc
> configure:3042: $? = 0
> configure:3031: gcc -V >&5
> gcc: error: unrecognized command line option '-V'
> It seems gcc does not like "-V" option. I this a issue to with later
> gcc versions?
> Thanks.
> sandeep
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
