[postgis-users] compiling from source code
Sandeep Gupta gupta.sandeep at gmail.com
Fri Jul 7 17:36:04 PDT 2017
Autoconf was missing, so I went ahead install autoconf, automake, and libtool.
Tried recompiling.
sh autogen.sh outputs:
* Running /home/linuxbrew/.linuxbrew/bin/glibtoolize (2.4.6)
   OPTIONS = --force --copy --install
glibtoolize: putting auxiliary files in '.'.
glibtoolize: copying file './config.guess'
glibtoolize: copying file './config.sub'
glibtoolize: copying file './install-sh'
glibtoolize: copying file './ltmain.sh'
glibtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'macros'.
glibtoolize: copying file 'macros/libtool.m4'
glibtoolize: copying file 'macros/ltoptions.m4'
glibtoolize: copying file 'macros/ltsugar.m4'
glibtoolize: copying file 'macros/ltversion.m4'
glibtoolize: copying file 'macros/lt~obsolete.m4'
glibtoolize: Consider adding '-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
* Running /home/linuxbrew/.linuxbrew/bin/aclocal (1.15.1)
* Running /home/linuxbrew/.linuxbrew/bin/autoconf (2.69)
Now you are ready to run './configure'
This does not solve though. When I run ./configure same error appears
with -V flag being the issue.
-sandeep
On Fri, Jul 7, 2017 at 6:33 PM, Regina Obe <lr at pcorp.us> wrote:
> Okay I just got an irc note from Even Roualt.  He is running Ubuntu 16.04 and gcc 5.4  and had no issue running
> sh autogen.sh
> ./configure
> So doesn't seem like it's a newer gcc issue unless if its 5.3 specific.
> I'm suspecting something with brew,  MacOS, or tool chain like autoconf.
> What does:
> autoconf --version
> Return?
> I get
> autoconf (GNU Autoconf) 2.69
> Copyright (C) 2012 Free Software Foundation, Inc.
> License GPLv3+/Autoconf: GNU GPL version 3 or later
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Sandeep Gupta
> Sent: Friday, July 07, 2017 6:18 PM
> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> Subject: Re: [postgis-users] compiling from source code
> Hi Regina,
>  Here is the output for gcc -v (install gcc from linuxbrew, which port of brew package manager of macOS):
> Reading specs from
> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0/specs
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
> Target: x86_64-unknown-linux-gnu
> Configured with: ../configure
> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5 --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --with-build-config=bootstrap-debug --disable-werror --with-pkgversion='Homebrew gcc 5.3.0'
> --with-bugurl=https://github.com/Homebrew/homebrew/issues
> --enable-plugin --disable-nls --disable-multilib Thread model: posix gcc version 5.3.0 (Homebrew gcc 5.3.0)
> Thanks.
> sandeep
> On Fri, Jul 7, 2017 at 5:52 PM, Regina Obe <lr at pcorp.us> wrote:
>> Steve and Sandeep,
>> Can you try gcc -v instead and let me know what that outputs?
>> I just checked our Debian PostGIS bot, and she's running gcc 5.2.1  and think she's running the newest of any of our bots . So I can 't rule out a newer gcc at fault here.
>> However if I do gcc -V, I get an error on her too, so that's not the issue here:
>> gcc: error: unrecognized command line option  ?~-V ?T
>> gcc: fatal error: no input files
>> compilation terminated.
>> However, lower case -v  (which is what I think configure uses, works just fine).
>> gcc -v
>> outputs:
>> Using built-in specs.
>> COLLECT_GCC=gcc
>> COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/5/lto-wrapper
>> Target: x86_64-linux-gnu
>> Configured with: ../src/configure -v --with-pkgversion='Debian
>> 5.2.1-22' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs
>> --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++
>> --prefix=/usr --program-suffix=-5 --enable-shared --ena
>> jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-amd64
>> --with-arch-directory=amd64
>> --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc
>> --enable-multiarch --with-arch-32=i586 --with-abi=m64
>> --with-multilib-list=m32,m64,mx32 --enable-m Thread model: posix gcc
>> version 5.2.1 20151010 (Debian 5.2.1-22)
>> I'm not sure where Sandeep's   gcc -V is coming from in configure, cause it looks like gcc -v works fine on his system too, but then somewhere down the line switches to upper case -V which is not a valid switch command even in lower gcc versions.
>> Thanks,
>> Regina
>> From: Stephen Woodbridge Date: Fri, Jul 7, 2017 at 2:09 PM
>> I get the same error running on Ubuntu 16.04 with:
>> $ gcc -V
>> gcc: error: unrecognized command line option  -V
>> Looks like the option should be --version $ gcc --version gcc (Ubuntu
>> 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 Copyright (C) 2015 Free
>> This is free software; see the source for copying conditions.  There
>> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
>> -Steve
>> On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
>> Hi,
>> I am using gcc version 5.3 to compile postgis on Fedora.
>> The compile  fails at the configure step.
>> I get the error:
>> configure: error: C preprocessor "gcc" fails sanity check See
>> `config.log' for more details
>> The relevant line in config.log:
>> configure:3031: gcc -v >&5
>> Reading specs from
>> ux-gnu/5.3.0/specs
>> COLLECT_GCC=gcc
>> configure:3042: $? = 0
>> configure:3031: gcc -V >&5
>> gcc: error: unrecognized command line option '-V'
>> It seems gcc does not like "-V" option. I this a issue to with later
>> gcc versions?
>> Thanks.
>> sandeep
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
