[postgis-users] raster2pgsql: out_db=false with -R flag (And Showing out_db rasters in QGIS)
Tumasgiu Rossini rossini.t at gmail.com
Tue May 2 05:26:23 PDT 2017
I think that raster2pgsql is indeed a mature tool, but it is the out-db
feature of postgis
which is maybe not widely used, and so the bugs takes more time to appear
because
of the fewer users.
2017-05-02 12:18 GMT+02:00 <Michael.Haertel at t-systems.com>:
> Hello Tumasgiu Rossini,
> thank you very much for your fast and comprehensive response. I was not
> aware of that bug yet but found so many references to raster2pgsql that I
> just assumed that it was a mature tool already.
> (And noted that I gave wrong parameter in the subject line of my mail,
> should have been R and not F).
> Good luck with your programming efforts. I guess it’s somewhat complex
> since you have to deal with the real pixel data.
> Regards,
> Michael
> *Von:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *Im
> Auftrag von *Tumasgiu Rossini
> *Gesendet:* Dienstag, 2. Mai 2017 12:08
> *An:* PostGIS Users Discussion
> *Betreff:* Re: [postgis-users] raster2pgsql: out_db=false with -F flag
> Hi,
> To answer your first question :
> the combination of the -s and -R options actually transforms out-db raster
> into in-db,
> it is a recent known bug, see https://lists.osgeo.org/
> pipermail/postgis-users/2017-April/042003.html
> for more information.
> For the latter question,
> Qgis uses gdal to fetch raster data from postgis and the out-db support is
> not implemented.
> You can though maybe use workarounds, more info here :
> https://lists.osgeo.org/pipermail/postgis-users/2017-April/042077.html
> https://lists.osgeo.org/pipermail/postgis-users/2017-April/042053.html
> Using out-db rasters and Qgis at my company, I am facing myself this
> problem and
> I am trying to implement out-db support in gdal, though I am no gdal
> developer
> and it is not a high priority feature.
> 2017-05-02 11:37 GMT+02:00 <Michael.Haertel at t-systems.com>:
> Dear users,
> I hope that somebody can tell me if I found a bug or simply don’t use the
> command correctly.
> Given:
> ·         A directory with four GeoTIFF files
> ·         PostgreSQL 9.6.1, compiled by Visual C++ build 1800, 64-bit
> ·         POSTGIS="2.3.1 r15264" GEOS="3.6.0-CAPI-1.10.0 r4265"
> SFCGAL="1.3.0" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.1, released
> 2016/07/07" LIBXML="2.7.8" LIBJSON="0.12" RASTER
> ·         OS is Windows 7
> I try to import the Tiff files as OUT_DB raster files using this command:
> 1.  raster2pgsql.exe -s 25832 -I -R -n myFilename -C -M -F
> C:\_GEODATA_\*.tif raster2x2 > t:\DTK10.sql
> Output:
> a.       Processing 1/4: C:\_GEODATA_\24_dtk10_32356_5608_2_nw_col.tif
> b.      Processing 2/4: C:\_GEODATA_\25_dtk10_32356_5610_2_nw_col.tif
> c.       Processing 3/4: C:\_GEODATA_\34_dtk10_32358_5608_2_nw_col.tif
> d.      Processing 4/4: C:\_GEODATA_\35_dtk10_32358_5610_2_nw_col.tif
> 2.  psql.exe --host=localhost --port=5432 --username=xxx --dbname=xxx -f
> t:\DTK10.sql
> Output:
> a.       BEGIN
> b.      CREATE TABLE
> c.       INSERT 0 1
> d.      INSERT 0 1
> e.      INSERT 0 1
> f.        INSERT 0 1
> g.       CREATE INDEX
> h.      ANALYZE
> i.         psql:t:/DTK10.sql:9: HINWEIS:  Adding SRID constraint
> j.        psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-X constraint
> k.       psql:t:/DTK10.sql:9: HINWEIS:  Adding scale-Y constraint
> l.         psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-X constraint
> m.    psql:t:/DTK10.sql:9: HINWEIS:  Adding blocksize-Y constraint
> n.      psql:t:/DTK10.sql:9: HINWEIS:  Adding alignment constraint
> o.      psql:t:/DTK10.sql:9: HINWEIS:  Adding number of bands constraint
> p.      psql:t:/DTK10.sql:9: HINWEIS:  Adding pixel type constraint
> q.      psql:t:/DTK10.sql:9: HINWEIS:  Adding nodata value constraint
> r.        psql:t:/DTK10.sql:9: HINWEIS:  Adding out-of-database constraint
> s.       psql:t:/DTK10.sql:9: HINWEIS:  Adding maximum extent constraint
> t.        addrasterconstraints
> u.      ----------------------
> v.       t
> Problem is that the view “raster_columns” always shows FALSE for out_db,
> even though I used the F flag:
> "r_table_catalog"
> "r_table_schema"
> "r_table_name"
> "r_raster_column"
> "srid"
> "scale_x"
> "scale_y"
> "blocksize_x"
> "blocksize_y"
> "same_alignment"
> "regular_blocking"
> "num_bands"
> "pixel_types"
> "nodata_values"
> "out_db"
> "extent"
> "spatial_index"
> "gismobile"
> "public"
> "raster2x2 "
> "rast"
> 25832
> 0.5
> -0.5
> 4000
> 4000
> true
> false
> 1
> {8BUI}
> {NULL}
> {f}
> 0103000020E864000001000000050000000000000080BA15410000000090
> 6455410000000080BA154100000000786855410000000000F91541000000
> 00786855410000000000F9154100000000906455410000000080BA15410000000090645541
> true
> "rid"
> "rast"
> "filename"
> 1
> 0100000100000000000000E03F000000000000E0BF0000000080BA154100
> 0000008466554100000000000000000000000000000000E8640000A00FA0
> 0F840000433A5C5F47454F444154415F5C32345F64746B31305F33323335
> 365F353630385F325F6E775F636F6C2E74696600
> "24_dtk10_32356_5608_2_nw_col.tif"
> 2
> 0000007868554100000000000000000000000000000000E8640000A00FA0
> 0F840000433A5C5F47454F444154415F5C32355F64746B31305F33323335
> 365F353631305F325F6E775F636F6C2E74696600
> "25_dtk10_32356_5610_2_nw_col.tif"
> 3
> 0100000100000000000000E03F000000000000E0BF00000000C0D9154100
> 0F840000433A5C5F47454F444154415F5C33345F64746B31305F33323335
> 385F353630385F325F6E775F636F6C2E74696600
> "34_dtk10_32358_5608_2_nw_col.tif"
> 4
> 0F840000433A5C5F47454F444154415F5C33355F64746B31305F33323335
> 385F353631305F325F6E775F636F6C2E74696600
> "35_dtk10_32358_5610_2_nw_col.tif"
> What I found out: As soon as I omit the s flag (to provide a SRS) the
> column shows TRUE.
> I guess that this is not the intended behaviour is it?
> My QGIS 2.18 only shows black boxes for out_db rasters, the rasters
> themselves (pixel values) only appear for “in-DB” rasters. Did anybody
> succeed in showing out_db rasters in QGIS?
> Interestiung is also that gdalinfo is not showing any extents although it
> shows correct SRS and the “extent” column is populated (see above):
> C:\_PortableApps_\pgsql\bin>"c:\QGIS\bin\gdalinfo.exe" PG:"dbname='xxx'
> host='localhost' port='5432' user='mhaerte2' password='xxx'
> table='raster2x2'"
> Driver: PostGISRaster/PostGIS Raster driver
> Files: none associated
> Size is 0, 0
> Coordinate System is:
> PROJCS["ETRS89 / UTM zone 32N",
>     GEOGCS["ETRS89",
>         DATUM["European_Terrestrial_Reference_System_1989",
>             SPHEROID["GRS 1980",6378137,298.257222101,
>                 AUTHORITY["EPSG","7019"]],
>             TOWGS84[0,0,0,0,0,0,0],
>             AUTHORITY["EPSG","6258"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4258"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",9],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AXIS["Easting",EAST],
>     AXIS["Northing",NORTH],
>     AUTHORITY["EPSG","25832"]]
> Subdatasets:
>          --- snip! --
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,    0.0)
> Upper Right (    0.0,    0.0)
> Lower Right (    0.0,    0.0)
> Center      (    0.0,    0.0)
> Does anyone have a clue?
> Thank you for your comments,
> Michael
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170502/5d418f8e/attachment.html>
