[postgis-users] PostGIS2 Fedora 28 Packages and GEOS issue
John Woltman john.woltman at tpiengineering.com
Mon May 21 06:30:53 PDT 2018
Hello all,
I am attempting to install PostGIS2 (specifically postgis2_95 for Postgres
9.5) on Fedora 28.  When I run ``sudo dnf install postgis23_95`` I get the
the following the error:
Error:
  Problem: conflicting requests
     - nothing provides geos36 >= 3.6.2 needed by postgis23_95
I'm using Postgres 9.5 & PostGIS 2.3 because that's what our production
system uses.  Fedora appears to be shipping GEOS 3.6.1.  Is there a way to
work around this (preferably without building from source), or is this a
bug in the PostGIS package that should be fixed?
Thank you,
John
John Woltman
TPI • 302 New Mill Lane • Exton, PA 19341 • (610) 524-7260
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180521/54f76427/attachment.html>
