[postgis-users] POINT Z geometry transformation issue
Klemen Špruk spruk.klemen at gmail.com
Fri May 25 05:22:34 PDT 2018
Hello!
I have a issue with Z coordinate value when transforming coordinates:
Simlple test on postgresql-postgis server:
with data as (
select st_setsrid(st_makepoint(466180.66, 110950.00, 500), 3912) as point)
select st_astext(data.point) as ok,
st_astext(st_transform(data.point, 3795)) as not_ok from data;
When transforming point to other SRID Z value is corrupted.
Query result:
DB server info: PostgreSQL 10.1 on x86_64-pc-linux-gnu, compiled by gcc
(Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit POSTGIS="2.4.3
r16312" PGSQL="100" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.2, 08
September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" RASTER
Does anyone have any idea why Z value is corrupted or I am I doing
something wrong or this is a bug?
Thank Klemen!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180525/bf1da5bd/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180525/bf1da5bd/attachment.png>
