[postgis-users] Dependencies for postgis25_12 not found (geos38, proj70)
Steve Pritchard steve.pritchard at bto.org
Thu May 7 06:45:08 PDT 2020
Thanks Devrim. I've installed the .rpmnew file, and yum now
finds geos38 (3.8.1) and proj70 (7.0.1) successfully.
I can't see how I could reasonably have known about this. I had looked on
https://yum.postgresql.org/, but I couldn't find any relevant info.
The repository change doesn't seem to appear in the "News" on the left-hand
side.
Could a News item be added in case others have similar problems?
It would be helpful if geos38 & proj70 could be mentioned specifically, so
that search engines will find the News item.
Steve
On Thu, 7 May 2020 at 13:58, Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> On Wed, 2020-05-06 at 09:40 -0400, Regina Obe wrote:
> > Sounds like a packaging mistake.  Both 3.8.1 and proj79 are stable so it
> is
> > possible they just weren’t pushed to stable branch.
> I  think it's an issue on user side. I bet they are not using the latest
> repo
> RPM:
> https://www.postgresql.org/about/news/2027/
> Steve, can you please use the latest repo RPM first?
> Regards,
> Devrim Gündüz
> Open Source Solution Architect, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
Steve Pritchard
Database Developer
British Trust for Ornithology, The Nunnery, Thetford, Norfolk IP24 2PU, UK
Tel: +44 (0)1842 750050, fax: +44 (0)1842 750030
Registered Charity No 216652 (England & Wales) No SC039193 (Scotland)
Company Limited by Guarantee No 357284 (England & Wales)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200507/7d3e434b/attachment.html>
