[postgis-users] Dependencies for postgis25_12 not found (geos38, proj70)
Devrim Gündüz devrim at gunduz.org
Fri May 8 02:57:02 PDT 2020
Hi Steve,
On Thu, 2020-05-07 at 14:45 +0100, Steve Pritchard wrote:
> Thanks Devrim. I've installed the .rpmnew file, and yum now
> finds geos38 (3.8.1) and proj70 (7.0.1) successfully.
Great!
> I can't see how I could reasonably have known about this. I had looked on
> https://yum.postgresql.org/, but I couldn't find any relevant info.
> The repository change doesn't seem to appear in the "News" on the left-hand
> side.
> Could a News item be added in case others have similar problems?
> It would be helpful if geos38 & proj70 could be mentioned specifically, so
> that search engines will find the News item.
Thanks for pointing it out. Updated website:
Regards,
Devrim Gündüz
Open Source Solution Architect, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200508/28559cd3/attachment.sig>
