[postgis-users] Queries slow after PostGIS upgrade
Kevin Berger Kevin.Berger at silvacom.com
Wed Oct 26 09:27:06 PDT 2022
We are migrating from a Windows Postgres Version 9.6.1 PostGIS Version 2.3.1 solution to an AWS RDS solution, Postgres Version 13.7 PostGIS Version 3.1.5. We used dump files to transfer the database contents to AWS, using pg_dump.exe to create schema dump files, then using psql to restore the dump files to the RDS instance.
However, we are finding that PostGIS database queries are taking significantly longer on RDS than on Windows (although querying non-PostGIS attribute data is actually faster). We are thinking this might be due to the PostGIS versioning, going from version 2 to version 3.
Any suggestions that we can do on the PostGIS side to improve query performance would be appreciated. Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221026/33657d85/attachment.htm>
