[postgis-users] Free Online or Cloud PostGreSQL and PostGIS
Brent Wood pcreso at yahoo.com
Sat Apr 1 14:02:47 PDT 2023
 I have a system at home I could set up an account for you to play with, no guarantees, etc. if that meets your immediate needs.
If you wanted something with some assurances of server/data security I think it likely you'll need to pay for the privilege.
There is a local (in New Zealand) provider that offers a nice service with good support (in my experience anyway). I don't know how the pricing compares with others:https://catalystcloud.nz/about/news/catalyst-clouds-kiwi-first-managed-database-service-now-with-postgresql-support/https://catalystcloud.nz/services/paas/managed-database/https://docs.catalystcloud.nz/
At about $NZ25 per month for a minimal system, that could be a cheap way to start, but you would need to scale up to support multiple users with significant data volumes.
This article may be of interest:https://www.prisma.io/dataguide/postgresql/5-ways-to-host-postgresql
I would also suggest that if you just want to try it out, any cheap x64 computer with 1Gb of memory or so will happily run a Linux setup (very easy to build) with Postgres/Postgis installed. The deployment process typically takes me about 20 minutes, I'm happy to help you through that if you want.
Cheers,
Brent Wood
    On Sunday, April 2, 2023 at 08:39:07 AM GMT+12, Alexandre Neto <senhor.neto at gmail.com> wrote:
 https://www.crunchydata.com/developers/playground, maybe?
A sexta, 31/03/2023, 19:59, Tahir Tamba <tahir.tamba at gmail.com> escreveu:
Hi, Is there a free PostgreSQL or PostGIS environment online or in the cloud allowing beginners to access the PostgreSQL and PostGIS server for learning purposes with the possibility of storing our own dataset?
Regards,
Tahir Tamba
6632 Avenue de Gaspé
Montréal (Québec) H2S 2Y2
Courriel: tahir.tamba at gmail.com
AVERTISSEMENT : Ce courriel et les pièces qui y sont jointes sont destinés exclusivement au(x) destinataire(s) mentionné(s) ci-dessus et peuvent contenir de l’information privilégiée ou confidentielle. Si vous avez reçu ce courriel par erreur, ou s’il ne vous est pas destiné, veuillez le mentionner immédiatement à l’expéditeur et effacer ce courriel ainsi que les pièces jointes, le cas échéant. La copie ou la redistribution non autorisée de ce courriel peut être illégale. Le contenu de ce courriel ne peut être interprété qu’en conformité avec les lois et règlements qui régissent les pouvoirs des diverses instances décisionnelles compétentes de la Ville de Montréal.
postgis-users mailing list
postgis-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230401/561665b7/attachment.htm>
