[postgis-users] ST_DWithin slow if query is joined to another table, but fast if ST_DWithin cast to an integer
Cameron McCloud cameron.mccloud at gmail.com
Thu Nov 9 00:54:09 PST 2023
Apologies, must have copied it in wrong when mailing.
The ON clause is there in the source code, otherwise that would be invalid
SQL.
On Wed, Nov 8, 2023 at 6:10 PM Regina Obe <lr at pcorp.us> wrote:
> First of all is that really your join clause?  You seem to be missing an ON
> from building b
> join customer c
> Also please output
> EXPLAIN
> And the
> EXPLAIN ANALYZE of each query
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Cameron McCloud via postgis-users
> *Sent:* Wednesday, November 8, 2023 5:38 AM
> *To:* postgis-users at lists.osgeo.org
> *Cc:* Cameron McCloud <cameron.mccloud at gmail.com>
> *Subject:* Re: [postgis-users] ST_DWithin slow if query is joined to
> Test code is here:
> https://github.com/cameronmccloud/postgis_slow_st_dwithin/blob/main/test.sql
> On Wed, Nov 8, 2023 at 9:25 AM Cameron McCloud <cameron.mccloud at gmail.com>
> wrote:
> Hi,
> Postgis Version: 3.3.4
> Postgres Version: 14.9
> We have 2 tables, "building" with lat/long and "customer" with a FK to
> building. There's a 1:1 relationship between the two.
> The test tables we're using have 16K rows each. Our production data has a
> lot more, but we could reproduce this on a smaller dataset.
> We found some odd behaviour when using ST_DWITHIN in a WHERE clause but
> only when the "building" table is joined to the "customer" table.
> We also found that converting the result of ST_DWITHIN to an integer (1/0
> for true/false) and using the integer in the WHERE is fast.
> -- This query works as expected and takes 60ms returning 6K rows.
> select b.*
> from building b
> where
>   st_dwithin(st_makepoint(b.longitude, b.latitude)::geography,
> st_makepoint(-96.7804060, 33.2471770)::geography, 50000);
> -- This query is orders of magnitude slower - 3000ms, even though joining
> the two tables without the WHERE takes 30ms
> select b.*
> from building b
> join customer c
> where
> -- This query converts the result of ST_DWITHIN to an integer. It's fast
> and takes 80ms
> select b.*
> from building b
> join customer c
> where
>   case st_dwithin(st_makepoint(b.longitude, b.latitude)::geography,
>     when true then 1
>     else 0
>   end = 1;
> We have no idea why this is the case, but we're curious. In our production
> scenario using the "case...when" brought a query down from 6 minutes to 6
> seconds. We'd love to know why this might be and if there are other
> scenarios like this that could increase the performance of our Postgis
> queries.
> Thanks,
> Cam.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231109/242f170f/attachment.htm>
