[postgis-users] ST_DWithin slow if query is joined to another table, but fast if ST_DWithin cast to an integer
Cameron McCloud cameron.mccloud at gmail.com
Thu Nov 9 01:00:01 PST 2023
The point still stands. With a join, the performance is a lot worse, more
so than accounting for the join itself.
On Thu, Nov 9, 2023 at 8:54 AM Cameron McCloud <cameron.mccloud at gmail.com>
wrote:
> Apologies, must have copied it in wrong when mailing.
> The ON clause is there in the source code, otherwise that would be invalid
> SQL.
> On Wed, Nov 8, 2023 at 6:10 PM Regina Obe <lr at pcorp.us> wrote:
>> First of all is that really your join clause?  You seem to be missing an
>> ON
>> from building b
>> join customer c
>> Also please output
>> EXPLAIN
>> And the
>> EXPLAIN ANALYZE of each query
>> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
>> Of *Cameron McCloud via postgis-users
>> *Sent:* Wednesday, November 8, 2023 5:38 AM
>> *To:* postgis-users at lists.osgeo.org
>> *Cc:* Cameron McCloud <cameron.mccloud at gmail.com>
>> *Subject:* Re: [postgis-users] ST_DWithin slow if query is joined to
>> Test code is here:
>> https://github.com/cameronmccloud/postgis_slow_st_dwithin/blob/main/test.sql
>> On Wed, Nov 8, 2023 at 9:25 AM Cameron McCloud <cameron.mccloud at gmail.com>
>> wrote:
>> Hi,
>> Postgis Version: 3.3.4
>> Postgres Version: 14.9
>> We have 2 tables, "building" with lat/long and "customer" with a FK to
>> building. There's a 1:1 relationship between the two.
>> The test tables we're using have 16K rows each. Our production data has a
>> lot more, but we could reproduce this on a smaller dataset.
>> We found some odd behaviour when using ST_DWITHIN in a WHERE clause but
>> only when the "building" table is joined to the "customer" table.
>> We also found that converting the result of ST_DWITHIN to an integer (1/0
>> for true/false) and using the integer in the WHERE is fast.
>> -- This query works as expected and takes 60ms returning 6K rows.
>> select b.*
>> from building b
>> where
>>   st_dwithin(st_makepoint(b.longitude, b.latitude)::geography,
>> st_makepoint(-96.7804060, 33.2471770)::geography, 50000);
>> -- This query is orders of magnitude slower - 3000ms, even though joining
>> the two tables without the WHERE takes 30ms
>> select b.*
>> from building b
>> join customer c
>> where
>> -- This query converts the result of ST_DWITHIN to an integer. It's fast
>> and takes 80ms
>> select b.*
>> from building b
>> join customer c
>> where
>>   case st_dwithin(st_makepoint(b.longitude, b.latitude)::geography,
>>     when true then 1
>>     else 0
>>   end = 1;
>> We have no idea why this is the case, but we're curious. In our
>> production scenario using the "case...when" brought a query down from 6
>> minutes to 6 seconds. We'd love to know why this might be and if there are
>> other scenarios like this that could increase the performance of our
>> Postgis queries.
>> Thanks,
>> Cam.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231109/0b64e81d/attachment.htm>
