[postgis-users] Postgis on RHEL8
Paul Ramsey pramsey at cleverelephant.ca
Thu Oct 12 12:19:44 PDT 2023
> On Oct 12, 2023, at 10:51 AM, Scott Pasnikowski via postgis-users <postgis-users at lists.osgeo.org> wrote:
> I am starting to think the path to stability if I need to use postgis is to just build the whole damn thing myself...
> Thoughts?
Or if your client values your time highly enough, for them to subscribe to a PostgreSQL support company that will provide validated and integration tested builds for RHEL8, and back you up if you run into problems. Then you can focus on the things that matter.
P.
