[postgis-users] generate a geometry column of random point, line and polygon
Shaozhong SHI shishaozhong at gmail.com
Mon Sep 11 00:20:46 PDT 2023
I tested St_optimalphashape and it does not work.
select gs,
st_optimalalphashape(st_collect(ST_MakePoint(random()*10,random()*10),ST_MakePoint(random()*10,random()*10))::geometry)
from generate_series(1,100) gs;
Example given here does not work either.
ST_OptimalAlphaShape (postgis.net)
<https://postgis.net/docs/en/ST_OptimalAlphaShape.html>
Regards,
David
On Fri, 8 Sept 2023 at 16:16, Regina Obe <lr at pcorp.us> wrote:
> David,
> The example query in the docs, is as simple as it gets.  It’s a
> self-contained example you can just run, but it does return a multipoint
> and I realize now the docs don’t make it clear ST_GeneratePoints returns a
> single geometry that is a multipoint.
> IF you want individual points, you’d combine with ST_DumpPoints.
> I’ll add such an example to the docs.
> So here is an example you can apply to a table of polygons
> For polygons you can do something like below where p is the table name and
> geom is the polygon column.
> This will generate 100 random points for each polygon
> SELECT p.id, dp.path[1], dp.geom
> FROM p, ST_DumpPoints(ST_GeneratePoints(p.geom, 100)) AS dp;
> The p.id and path I just threw in cause I find them useful, but you could
> leave them out.
> Here is a self-contained using the example table in docs:
> WITH p AS (  SELECT 1 AS id, ST_Buffer(
>         ST_GeomFromText(
>         'LINESTRING(50 50,150 150,150 50)'),
>         10, 'endcap=round join=round') AS geom)
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Shaozhong SHI
> *Sent:* Friday, September 8, 2023 10:54 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] generate a geometry column of random
> The simplicity is beautiful.  Any simple script to do so?  I think that
> will be an useful addition.
> Regards,
> David
> On Friday, 8 September 2023, Regina Obe <lr at pcorp.us> wrote:
> David,
> For this are you needing to generate random points from a line or polygon
> or are you trying to generate random polygons, lines, and points?
> If you need to generate random points from a polygon:
> Use ST_GeneratePoints:  https://postgis.net/docs/en/ST_GeneratePoints.html
> Note there is a option seed argument, that will give you the same exact
> answer if you give it the same seed, but without that the generated points
> will be different each time.
> As I recall, ST_GeneratePoints only works with areals so won’t work with a
> line, however you can buffer a line very thinly to do the same. Use a flat
> buffer:
> https://postgis.net/docs/en/ST_Buffer.html
> SELECT ST_GeneratePoints(ST_Buffer(
> ST_GeomFromText(
> ), 0.5, 'endcap=square join=round'), 1000);
> If you want to generate random polygons, you could use ST_ConcaveHull or
> ST_AlphaShape around the section of a polygon you did a ST_GeneratePoints on
> And then use something like https://postgis.net/docs/en/ST_Subdivide.html
> to chop up the polygons.
> To get a linestring out of that (It will be closed), you can take the
> boundary of any of the above
> https://postgis.net/docs/ST_Boundary.html
> Hope that helps,
> Regina
> Of *Shaozhong SHI
> *Sent:* Friday, September 8, 2023 7:56 AM
> *Subject:* [postgis-users] generate a geometry column of random point,
> line and polygon
> Is a simple way to do this?
> Regards,
> David
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230911/e9e6df92/attachment.htm>
