[postgis-users] generate a geometry column of random point, line and polygon
Regina Obe lr at pcorp.us
Mon Sep 11 00:30:45 PDT 2023
You are using the wrong version of ST_Collect.  You want to use the aggregate form.  You are using the two point form  - https://postgis.net/docs/en/ST_Collect.html
Also when you aggregate, you can’t include the gs in there.
Try:
SELECT  min(gs) , max(gs), st_optimalalphashape(st_collect(ST_MakePoint(random()*10,random()*10)) )
from generate_series(1,100) gs;
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Shaozhong SHI
Sent: Monday, September 11, 2023 3:21 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] generate a geometry column of random point, line and polygon
I tested St_optimalphashape and it does not work.
select gs, st_optimalalphashape(st_collect(ST_MakePoint(random()*10,random()*10),ST_MakePoint(random()*10,random()*10))::geometry)
Example given here does not work either.
ST_OptimalAlphaShape (postgis.net) <https://postgis.net/docs/en/ST_OptimalAlphaShape.html>
Regards,
David
On Fri, 8 Sept 2023 at 16:16, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
David,
The example query in the docs, is as simple as it gets.  It’s a self-contained example you can just run, but it does return a multipoint and I realize now the docs don’t make it clear ST_GeneratePoints returns a single geometry that is a multipoint.
IF you want individual points, you’d combine with ST_DumpPoints.
I’ll add such an example to the docs.
So here is an example you can apply to a table of polygons
For polygons you can do something like below where p is the table name and geom is the polygon column.
This will generate 100 random points for each polygon
SELECT p.id <http://p.id> , dp.path[1], dp.geom
FROM p, ST_DumpPoints(ST_GeneratePoints(p.geom, 100)) AS dp;
The p.id <http://p.id>  and path I just threw in cause I find them useful, but you could leave them out.
Here is a self-contained using the example table in docs:
WITH p AS (  SELECT 1 AS id, ST_Buffer(
        ST_GeomFromText(
        'LINESTRING(50 50,150 150,150 50)'),
        10, 'endcap=round join=round') AS geom)
From: postgis-users <postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> > On Behalf Of Shaozhong SHI
Sent: Friday, September 8, 2023 10:54 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
The simplicity is beautiful.  Any simple script to do so?  I think that will be an useful addition.
Regards,
David
On Friday, 8 September 2023, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
David,
For this are you needing to generate random points from a line or polygon or are you trying to generate random polygons, lines, and points?
If you need to generate random points from a polygon:
Use ST_GeneratePoints:  https://postgis.net/docs/en/ST_GeneratePoints.html
Note there is a option seed argument, that will give you the same exact answer if you give it the same seed, but without that the generated points will be different each time.
As I recall, ST_GeneratePoints only works with areals so won’t work with a line, however you can buffer a line very thinly to do the same. Use a flat buffer:
https://postgis.net/docs/en/ST_Buffer.html
SELECT ST_GeneratePoints(ST_Buffer(
ST_GeomFromText(
), 0.5, 'endcap=square join=round'), 1000);
If you want to generate random polygons, you could use ST_ConcaveHull or ST_AlphaShape around the section of a polygon you did a ST_GeneratePoints on
And then use something like https://postgis.net/docs/en/ST_Subdivide.html to chop up the polygons.
To get a linestring out of that (It will be closed), you can take the boundary of any of the above
https://postgis.net/docs/ST_Boundary.html
Hope that helps,
Regina
Sent: Friday, September 8, 2023 7:56 AM
Subject: [postgis-users] generate a geometry column of random point, line and polygon
Is a simple way to do this?
Regards,
David
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230911/f02f0d04/attachment.htm>
