[postgis-users] ArcGIS Online without ArcGIS server
Martin Davis mtnclimb at gmail.com
Fri Sep 15 08:42:56 PDT 2023
It's my educated guess that the answer is no.  The AGOL client talks via
web services to the backend, so it can't talk directly to a database server.
It *might* be able to talk to a non-AGOL web service (probably using OGC
protocols)?
On Fri, Sep 15, 2023 at 8:26 AM Regina Obe <lr at pcorp.us> wrote:
> This may be a question to just people using ArcGIS Online or at least
> familiar with it.  Is it possible to have an ArcGIS online connect to a
> PostGIS enabled database (assuming you have the port open etc), without an
> ArcGIS Server license?
> If so are their limitations in terms of what features you can use of ArcGIS
> Online like their javascript apis etc?
> Thanks,
> Regina
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230915/644c7f10/attachment.htm>
