[postgis-users] ArcGIS Online without ArcGIS server
Phil Bartie philbartie at gmail.com
Fri Sep 15 09:19:01 PDT 2023
ArcGIS online supports WMS, WMTS, and WFS OGC web services.
https://doc.arcgis.com/en/arcgis-online/manage-data/add-item-from-url.htm
Best,
Phil
On Fri, 15 Sept 2023 at 16:43, Martin Davis <mtnclimb at gmail.com> wrote:
> It's my educated guess that the answer is no.  The AGOL client talks via
> web services to the backend, so it can't talk directly to a database server.
> It *might* be able to talk to a non-AGOL web service (probably using OGC
> protocols)?
> On Fri, Sep 15, 2023 at 8:26 AM Regina Obe <lr at pcorp.us> wrote:
>> This may be a question to just people using ArcGIS Online or at least
>> familiar with it.  Is it possible to have an ArcGIS online connect to a
>> PostGIS enabled database (assuming you have the port open etc), without an
>> ArcGIS Server license?
>> If so are their limitations in terms of what features you can use of
>> ArcGIS
>> Online like their javascript apis etc?
>> Thanks,
>> Regina
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230915/a579ddc1/attachment.htm>
