GDAL dependencies during PostGIS upgrade
Nikhil Shetty nikhil.dba04 at gmail.com
Thu Feb 15 20:37:20 PST 2024
Hi Team,
We are planning to upgrade postgres to 15 and postgis from 3.1.2 to 3.3.5.
While installing postgis 3.3.5 we found some dependency issues with gdal36,
we were able to workaround by removing postgis 3.1.2 and gdal32 packages
but for postgres upgrade we need both postgis (3.1.2 and 3.3.5) packages to
be present.
Below is the issue when installing gdal36 which is required for postgis
3.3.5
-0-root@<host1>:/tmp # yum install gdal36-libs-3.6.4-6PGDG.rhel8.x86_64.rpm
> Last metadata expiration check: 0:00:58 ago on Wed 31 Jan 2024 02:01:35 PM
> UTC.
> Error:
> Problem: problem with installed package gdal32-libs-3.2.3-1.rhel8.x86_64
> - package gdal32-libs-3.2.3-1.rhel8.x86_64 requires
> libarmadillo.so.9()(64bit), but none of the providers can be installed
> - package gdal32-libs-3.2.2-13.rhel8.x86_64 requires
> - cannot install both armadillo-12.6.6-1.el8.x86_64 and
> armadillo-9.700.2-1.el8.x86_64
> - cannot install both armadillo-9.700.2-1.el8.x86_64 and
> - package gdal36-libs-3.6.4-6PGDG.rhel8.x86_64 requires
> libarmadillo.so.12()(64bit), but none of the providers can be installed
> - conflicting requests
> (try to add '—allowerasing' to command line to replace conflicting
> packages or '—skip-broken' to skip uninstallable packages or '—nobest' to
> use not only best candidate packages)
Thanks,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240216/5ad42d98/attachment.htm>
