Problem to Upgrade from 3.2.3 to 3.4.0
Arnaud Vandecasteele arnaud.sig at gmail.com
Sun Feb 18 23:33:59 PST 2024
I've done your solution and indeed it works !
Thanks for your help.
Arnaud
On Fri, Feb 16, 2024 at 2:42 PM Sandro Santilli <strk at kbt.io> wrote:
> On Wed, Feb 14, 2024 at 05:09:44PM +0400, Arnaud Vandecasteele wrote:
> > The default_version is still 3.2.3 and I suppose this is why postgis
> > doesn't really upgrade. It only keeps the same version.
> > Do you know how I could resolve this issue ?
> Whichever version is installed last determines the default version,
> so I guess 3.2.3 was installed *after* 3.4.0.
> You'll have to re-install the newer PostGIS version.
> Maybe take the chance to directly install 3.4.2
> (released on Feb 08, 2024) to get more bug fixes.
> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240219/f69566ab/attachment.htm>
