GDAL dependencies during PostGIS upgrade
Devrim Gündüz devrim at gunduz.org
Wed Feb 21 02:21:30 PST 2024
On Tue, 2024-02-20 at 22:37 +0530, Nikhil Shetty wrote:
> I upgraded the existing PostGIS 3.1.2 to 3.3.5 on PG13 but now when I
> am trying to install PostGIS 3.3.5 for PG15 , I am getting below error
> Error: Transaction test error:
>   file /usr/lib/.build-id/b6/89201f4430759c8544cd168dc6ba3e24f7d912
> from install of postgis33_15-client-3.3.5-1PGDG.rhel8.x86_64 conflicts
> with file from package postgis33_13-client-3.3.5-1PGDG.rhel8.x86_64
(RPM packager speaking) From packaging point of view this means
raster2pgsql has the same build id between 13 and 15, so that's why you
are seeing this error.  Let me see if I can do something there. Until
then please remove postgis33_13 client package  as it does not have
anything to do with the update. After you are done, you can install
postgis33_15.
Regards,
Devrim Gündüz
Open Source Solution Architect, PostgreSQL Major Contributor
Twitter: @DevrimGunduz , @DevrimGunduzTR
