GDAL dependencies during PostGIS upgrade
Nikhil Shetty nikhil.dba04 at gmail.com
Wed Feb 21 03:26:26 PST 2024
Hi Regina, Devirim,
Thank you for the details. We will try to uninstall the old version and
then install the new version.
Thanks,
Nikhil
On Wed, Feb 21, 2024 at 3:51 PM Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> On Tue, 2024-02-20 at 22:37 +0530, Nikhil Shetty wrote:
> > I upgraded the existing PostGIS 3.1.2 to 3.3.5 on PG13 but now when I
> > am trying to install PostGIS 3.3.5 for PG15 , I am getting below error
> > Error: Transaction test error:
> >   file /usr/lib/.build-id/b6/89201f4430759c8544cd168dc6ba3e24f7d912
> > from install of postgis33_15-client-3.3.5-1PGDG.rhel8.x86_64 conflicts
> > with file from package postgis33_13-client-3.3.5-1PGDG.rhel8.x86_64
> (RPM packager speaking) From packaging point of view this means
> raster2pgsql has the same build id between 13 and 15, so that's why you
> are seeing this error.  Let me see if I can do something there. Until
> then please remove postgis33_13 client package  as it does not have
> anything to do with the update. After you are done, you can install
> postgis33_15.
> Regards,
> Devrim Gündüz
> Open Source Solution Architect, PostgreSQL Major Contributor
> Twitter: @DevrimGunduz , @DevrimGunduzTR
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240221/bdd27e91/attachment.htm>
