ST_OrientedEnvelope returning parallelogram
Martin Davis mtnclimb at gmail.com
Fri Mar 8 12:40:07 PST 2024
Why do you think this result is wrong?  It's the same as the result I'm
seeing, and is an oriented rectangle enclosing the input (apart from minor
issues with numerical precision).
On Fri, Mar 8, 2024 at 12:32 PM Erik Wienhold <ewie at ewie.name> wrote:
> On 2024-03-08 20:36 +0100, Martin Davis wrote:
> > I can't reproduce this with GEOS 3.12 (either via PostGIS
> > ST_OrientedEnvelope or natively in GEOS).  The output is rectangular and
> as
> > expected.
> > SELECT ST_AsText(ST_OrientedEnvelope('POLYGON((-71.25961696926942
> > 42.470522973159675,-71.25978846747648
> 42.470624424600906,-71.25973918365264
> > 42.47066975346566,-71.25956768540266 42.47056830210077,-71.25961696926942
> > 42.470522973159675))'));
> >                   st_astext
> >  POLYGON((-71.25975582815524 42.470679599674035,-71.25956768540266
> > 42.47056830210077,-71.25960032476851 42.4705131269523,-71.25978846752108
> > 42.47062442452555,-71.25975582815524 42.470679599674035))
> > bin/geosop -a "POLYGON((-71.25961696926942
> > 42.470522973159675))" minAreaRectangle
> > POLYGON ((-71.25975582815524 42.470679599674035, -71.25956768540266
> > 42.47056830210077, -71.25960032476851 42.4705131269523,
> -71.25978846752108
> > 42.470624424525546, -71.25975582815524 42.470679599674035))
> > [image: image.png]
> > Is it possible the OP diagram is misleading?  Hard to tell since the full
> > output is not available.
> > @Erik: your repro is surprising. Can you post your query with output, and
> > the postgis_full_version() ?
> There you go:
>         SELECT postgis_full_version();
>          POSTGIS="3.4.1 POSTGIS_REVISION" [EXTENSION] (liblwgeom version
> mismatch: "3.4.1 ca035b9") PGSQL="160" GEOS="3.12.0-CAPI-1.18.0"
> PROJ="9.3.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
> LIBXML="2.12.1" LIBJSON="0.17" LIBPROTOBUF="1.5.0" WAGYU="0.5.0 (Internal)"
> (core procs from "3.4.1 ca035b9" need upgrade)
>         (1 row)
>         SELECT st_astext(ST_OrientedEnvelope(
>             'POLYGON((-71.25961696926942 42.470522973159675,
>                       -71.25978846747648 42.470624424600906,
>                       -71.25973918365264 42.47066975346566,
>                       -71.25961696926942 42.470522973159675))'));
>                             st_astext
>         (1 row)
> Erik
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240308/e947658a/attachment.htm>
