Error during gdal 3.5.3 Installation dependency libarmadillo
Nikhil Shetty nikhil.dba04 at gmail.com
Tue Mar 12 00:16:01 PDT 2024
Hi Team,
I am getting below error when installing gdal 3.5.3
yum install gdal35-libs-3.5.3-7PGDG.rhel8.x86_64.rpm
> Last metadata expiration check: 0:00:02 ago on Tue 12 Mar 2024 07:00:40 AM
> UTC.
> Error:
>  Problem: conflicting requests
>   - nothing provides libarmadillo.so.10()(64bit) needed by
> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
> to use not only best candidate packages)
gdal 3.5.3 is required by postgis 3.3.3
 yum install postgis33_15-3.3.3-1.rhel8.x86_64.rpm
> Denali 2.0
>                                           83 kB/s | 1.5 kB     00:00
> epic-infra-prod
>                                         1.1 MB/s | 2.5 kB     00:00
> Error:
>   - nothing provides libgdal.so.31()(64bit) needed by
>   - nothing provides gdal35-libs >= 3.5.3 needed by
I came across this document
https://www.postgresql.org/message-id/fb123015d4cbf69703aa8405810368bf0ca159fe.camel%40gunduz.org
, but this is for gdal v3.6.4
Thanks,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240312/5e39b1e3/attachment.htm>
