Error during gdal 3.5.3 Installation dependency libarmadillo
Nikhil Shetty nikhil.dba04 at gmail.com
Tue Mar 12 00:26:16 PDT 2024
We have enabled epel repo as well.
yum repolist | grep epel
> *epel*                                    *epel*
On Tue, Mar 12, 2024 at 12:46 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
wrote:
> Hi Team,
> I am getting below error when installing gdal 3.5.3
> yum install gdal35-libs-3.5.3-7PGDG.rhel8.x86_64.rpm
>> Last metadata expiration check: 0:00:02 ago on Tue 12 Mar 2024 07:00:40
>> AM UTC.
>> Error:
>>  Problem: conflicting requests
>>   - nothing provides libarmadillo.so.10()(64bit) needed by
>> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
>> to use not only best candidate packages)
> gdal 3.5.3 is required by postgis 3.3.3
>  yum install postgis33_15-3.3.3-1.rhel8.x86_64.rpm
>> Denali 2.0
>>                                           83 kB/s | 1.5 kB     00:00
>> epic-infra-prod
>>                                           1.1 MB/s | 2.5 kB     00:00
>> Error:
>>   - nothing provides libgdal.so.31()(64bit) needed by
>>   - nothing provides gdal35-libs >= 3.5.3 needed by
> I came across this document
> https://www.postgresql.org/message-id/fb123015d4cbf69703aa8405810368bf0ca159fe.camel%40gunduz.org
> , but this is for gdal v3.6.4
> Thanks,
> Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240312/9a35dba4/attachment.htm>
