Error during gdal 3.5.3 Installation dependency libarmadillo
Nikhil Shetty nikhil.dba04 at gmail.com
Tue Mar 12 02:04:28 PDT 2024
I installed armadillo package and found that libarmadillo is installed
 ls /usr/lib64/libarmadillo*
> /usr/lib64/libarmadillo.so  /usr/lib64/libarmadillo.so.12
> /usr/lib64/libarmadillo.so.12.6.6
but we are still getting error when installing gdal-libs
yum install gdal35-libs-3.5.3-7PGDG.rhel8.x86_64.rpm
> Last metadata expiration check: 0:00:28 ago on Tue 12 Mar 2024 08:50:43 AM
> UTC.
> Error:
>  Problem: conflicting requests
>   - nothing provides libarmadillo.so.10()(64bit) needed by
> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
> to use not only best candidate packages)
gdal is looking for armadillo v10 but our repo is configured with v12.
Thanks,
Nikhil
On Tue, Mar 12, 2024 at 12:56 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
wrote:
> We have enabled epel repo as well.
> yum repolist | grep epel
>> *epel*                                    *epel*
> On Tue, Mar 12, 2024 at 12:46 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
> wrote:
>> Hi Team,
>> I am getting below error when installing gdal 3.5.3
>>> Last metadata expiration check: 0:00:02 ago on Tue 12 Mar 2024 07:00:40
>>> AM UTC.
>>> Error:
>> gdal 3.5.3 is required by postgis 3.3.3
>>  yum install postgis33_15-3.3.3-1.rhel8.x86_64.rpm
>>> Denali 2.0
>>>                                             83 kB/s | 1.5 kB     00:00
>>> epic-infra-prod
>>>                                           1.1 MB/s | 2.5 kB     00:00
>>> Error:
>>>   - nothing provides libgdal.so.31()(64bit) needed by
>>>   - nothing provides gdal35-libs >= 3.5.3 needed by
>> I came across this document
>> https://www.postgresql.org/message-id/fb123015d4cbf69703aa8405810368bf0ca159fe.camel%40gunduz.org
>> , but this is for gdal v3.6.4
>> Thanks,
>> Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240312/54cb3ae2/attachment.htm>
