Error during gdal 3.5.3 Installation dependency libarmadillo
Nikhil Shetty nikhil.dba04 at gmail.com
Tue Mar 12 02:17:02 PDT 2024
As I see from the fedora repository, armadillo v10 is only available in
Linux v7 ----> https://dl.fedoraproject.org/pub/epel/7/x86_64/Packages/a/
For Linux v8, armadillo version is 12.
On Tue, Mar 12, 2024 at 2:34 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
wrote:
> I installed armadillo package and found that libarmadillo is installed
>  ls /usr/lib64/libarmadillo*
>> /usr/lib64/libarmadillo.so  /usr/lib64/libarmadillo.so.12
>> /usr/lib64/libarmadillo.so.12.6.6
> but we are still getting error when installing gdal-libs
> yum install gdal35-libs-3.5.3-7PGDG.rhel8.x86_64.rpm
>> Last metadata expiration check: 0:00:28 ago on Tue 12 Mar 2024 08:50:43
>> AM UTC.
>> Error:
>>  Problem: conflicting requests
>>   - nothing provides libarmadillo.so.10()(64bit) needed by
>> (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
>> to use not only best candidate packages)
> gdal is looking for armadillo v10 but our repo is configured with v12.
> Thanks,
> Nikhil
> On Tue, Mar 12, 2024 at 12:56 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
> wrote:
>> We have enabled epel repo as well.
>> yum repolist | grep epel
>>> *epel*                                    *epel*
>> On Tue, Mar 12, 2024 at 12:46 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
>> wrote:
>>> Hi Team,
>>> I am getting below error when installing gdal 3.5.3
>>>> Last metadata expiration check: 0:00:02 ago on Tue 12 Mar 2024 07:00:40
>>>> AM UTC.
>>>> Error:
>>>> '--nobest' to use not only best candidate packages)
>>> gdal 3.5.3 is required by postgis 3.3.3
>>>  yum install postgis33_15-3.3.3-1.rhel8.x86_64.rpm
>>>> Denali 2.0
>>>>                                             83 kB/s | 1.5 kB     00:00
>>>> epic-infra-prod
>>>>                                             1.1 MB/s | 2.5 kB     00:00
>>>> Error:
>>>>   - nothing provides libgdal.so.31()(64bit) needed by
>>>>   - nothing provides gdal35-libs >= 3.5.3 needed by
>>> I came across this document
>>> https://www.postgresql.org/message-id/fb123015d4cbf69703aa8405810368bf0ca159fe.camel%40gunduz.org
>>> , but this is for gdal v3.6.4
>>> Thanks,
>>> Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240312/e931738b/attachment.htm>
