Database crash when creating raster_in function
Regina Obe lr at pcorp.us
Sat Mar 16 21:37:41 PDT 2024
Yap that was fixed in PostGIS 3.3.3.
The change there was to support a change in PG16, so you shouldn’t need it for upgrading from PG13 to PG15.
Are you using postgis_raster or you just have it installed?
If you don’t need postgis_raster, I would suggest uninstalling it before upgrading.
Sent: Saturday, March 16, 2024 10:55 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Database crash when creating raster_in function
Hi Team,
I am trying to upgrade the postgres database from PG13 to PG15. pg_upgrade is crashing with below error when creating the raster_in function
pg_restore: creating FUNCTION "public.raster_in("cstring")"
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 394; 1255 16439 FUNCTION raster_in("cstring") postgres
pg_restore: error: could not execute query: server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
Command was: CREATE FUNCTION "public"."raster_in"("cstring") RETURNS "public"."raster"
    LANGUAGE "c" IMMUTABLE STRICT PARALLEL SAFE
    AS '$libdir/postgis_raster-3', 'RASTER_in';
PostGIS version : 3.3.5
This looks similar to the issue mentioned in https://trac.osgeo.org/postgis/ticket/5277. Is this fixed in 3.3.5 ?
Thanks,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240317/f705ff65/attachment.htm>
