[OSRS-PROJ] java port of proj-4
James Macgill j.macgill at geog.leeds.ac.uk
Sun Apr 2 07:46:33 PDT 2000
I am looking to improve support for projections in my open source Java
mapping toolkit geotools.
proj seems like a good place to start so I'm looking to port the code into
a Java class library that can be used separately or in conjunction with
geotools.
Before I start however, I would like to check that an open source
implementation of the code is not already available in Java so that I don't
waste my time re-implementing it.
If there is no existing port then I will set to work.  Is there a set of
test files that I could use to put through any code that I write to check
that I am getting the right results?
Thanks in anticipation
James.
James Macgill
Center for Computational Geography
GeoTools - The open source Java mapping toolkit
http://www.ccg.leeds.ac.uk/geotools
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
