[OSRS-PROJ] java port of proj-4
Frank Warmerdam warmerda at home.com
Sun Apr 2 15:05:34 PDT 2000
James Macgill wrote:
> I am looking to improve support for projections in my open source Java
> mapping toolkit geotools.
> proj seems like a good place to start so I'm looking to port the code into
> a Java class library that can be used separately or in conjunction with
> geotools.
> Before I start however, I would like to check that an open source
> implementation of the code is not already available in Java so that I don't
> waste my time re-implementing it.
> If there is no existing port then I will set to work.  Is there a set of
> test files that I could use to put through any code that I write to check
> that I am getting the right results?
James,
You might want to look at OpenMap for Java implementations of a few
projections, but I am not aware of an OpenSource projections library
with the breadth of PROJ.
I am not aware of a set of test data files, but you should be able to
create these easily, and compare projection results from PROJ and your newly
developed libraries.  I am also interested in doing some comparison of
results between PROJ, GCTP and Geotrans to verify that everything is kosher.
Later,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
